Home > Technical (L322) > Intermittent starting problem
autobiorob
England 2004 Range Rover Autobiography 4.4 V8 Zambezi Silver
Hi all
Have a starting problem where sometimes I will go to start her and she is fine but other times there is nothing there and I have to turn the key on and off several times before she starts. I have read somewhere on the forum about this problem with others but cannot find it now. Any ideas?
Post #100613 7th Jan 2012 11:07am
could it be the gear switch? that needs adjusting....... lift the console up and have a look.. ... - .- -.
Post #100614 7th Jan 2012 11:12am
M44K TS
Try wiggling the ignition barrel when the key is in, could be that it's worn slightly. Could also be a loose connection on the starter motor. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #100620 7th Jan 2012 11:44am
autobiorob
Just had a new lock set so not the ignition barrel.Kept trying it in neutral earlier and it was fine but soon as I have it in park then that's when the problem occurs. As I'm not mechanically minded at all, how will I know if the gear switch wants adjusting
Post #100650 7th Jan 2012 3:05pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Check your battery earth adn the Pos and neg connector are tight. Mine lost ALL power once when driving along. It was a loose connection to the battery!
Post #100661 7th Jan 2012 4:09pm
kb5
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Does this happen on first start up or can it happen even after you have driven the car and it's warm? I had this problem and turned out to be fuel pump. Thumbs Up
Post #102198 18th Jan 2012 8:58am
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
I have the same problem ... scarey what console you talking about? so give a look ... Thumbs Up
Post #102204 18th Jan 2012 9:19am
centre console ..around where the ignition switch is you can see the mechanics...look on the wiki for ''top tips'' and ''key stuck in ignition'' and you'll see how it all looks and what could be lubricated.. ... - .- -.
Post #102210 18th Jan 2012 9:39am
autobiorob
Narrowed mine down to wiring but where is another question
Post #102506 19th Jan 2012 8:46pm
