Home > Technical (L322) > Intermittent starting problem |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35325 |
could it be the gear switch? that needs adjusting....... lift the console up and have a look.. ... - .- -.
7th Jan 2012 11:12am |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
Try wiggling the ignition barrel when the key is in, could be that it's worn slightly. Could also be a loose connection on the starter motor. 2006 Mercedes CLS
7th Jan 2012 11:44am |
autobiorob Member Since: 18 Nov 2011 Location: Peterborough Posts: 33 |
Just had a new lock set so not the ignition barrel.Kept trying it in neutral earlier and it was fine but soon as I have it in park then that's when the problem occurs. As I'm not mechanically minded at all, how will I know if the gear switch wants adjusting |
7th Jan 2012 3:05pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3161 |
Check your battery earth adn the Pos and neg connector are tight. Mine lost ALL power once when driving along. It was a loose connection to the battery! |
7th Jan 2012 4:09pm |
kb5 Member Since: 20 Jan 2010 Location: currently in The Sudan, dont ask Posts: 63 |
Does this happen on first start up or can it happen even after you have driven the car and it's warm? I had this problem and turned out to be fuel pump. |
18th Jan 2012 8:58am |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 |
I have the same problem ... scarey what console you talking about? so give a look ... |
18th Jan 2012 9:19am |
centre console ..around where the ignition switch is you can see the mechanics...look on the wiki for ''top tips'' and ''key stuck in ignition'' and you'll see how it all looks and what could be lubricated.. ... - .- -.
18th Jan 2012 9:39am |
Narrowed mine down to wiring but where is another question |
19th Jan 2012 8:46pm |
