![]() | Home > In Car Electronics (L322) > satnav unit |
dave.s Member Since: 01 Nov 2011 Location: Isle of Wight Posts: 127 ![]() ![]() ![]() |
thought i would look at updating satnav to a mk4 unit, but on looking at mine
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
talked about loads , might be worth doing a search dave.. ... - .- -.
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Best bet is to whip it out and check the connectors on the back and see if they are the same as the MkIV - from memory there are two connectors - one burgundy and one blue.
have been searching for ages it was more a case of not being the one i expected. it is this one, hoped someone might recognise it. [img]http://www.bba-reman.com/content.aspx?content=Range-Rover-SatNav-Unit[/img]
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
Think BBA-Reman fix or remanufacture ECUs and other electrical bits when they break.
is yours a touch screen dave? ... - .- -.
hi Rads, it is a dvd system so does that mean a refurbed mk 4 bmw unit?
hi Scarey, yes it is touch screen.
Hi Daveo,can the unit be changed or am i stuck with it, or can i get an updated disc
you can get a 2009/2010 or 2011/12 discs...the first one is a firmware and mapping upgrade the second is just the mapping....there are pirate discs available but we cant discus that here or the proper ones cost around £150 from dealers. ... - .- -.
cheers Scarey, will keep my eyes open for a 2009/2010 disc or if someone has one for sale let me know.
