Home > In Car Electronics (L322) > satnav unit
dave.s
satnav unit
thought i would look at updating satnav to a mk4 unit, but on looking at mine
it does not seem to be the one i was expecting to see. my 2005 pre facelift has
part no 462100-8318,cant find any info on this other than company called bba-reman.
i did call them but useless, does anyone know about these, are they a straight swap,
do they have an aux output on rear. just thought i would ask before having to take it out.
dave
Post #100419 5th Jan 2012 3:51pm
talked about loads , might be worth doing a search dave.. ... - .- -.
Post #100422 5th Jan 2012 4:11pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Best bet is to whip it out and check the connectors on the back and see if they are the same as the MkIV - from memory there are two connectors - one burgundy and one blue.
Make sure the system has fully powered down before removing it (takes two or three minutes for the red light to go out).
Post #100423 5th Jan 2012 4:13pm
dave.s
have been searching for ages it was more a case of not being the one i expected. it is this one, hoped someone might recognise it. [img]http://www.bba-reman.com/content.aspx?content=Range-Rover-SatNav-Unit[/img]
don't seem to be able to copy pic so you may to copy link
dave
Post #100427 5th Jan 2012 4:45pm
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
Think BBA-Reman fix or remanufacture ECUs and other electrical bits when they break.
Should be the same as an original unit, but just with their labels and part numbers.
Bottom line is, CD based unit is a MK3, DVD based is a MKIV. What does yours say on it, adjacent to the disk slot?
HTH
David
Post #100438 5th Jan 2012 5:41pm
is yours a touch screen dave? ... - .- -.
Post #100439 5th Jan 2012 5:42pm
dave.s
hi Rads, it is a dvd system so does that mean a refurbed mk 4 bmw unit?
dave
Post #100447 5th Jan 2012 7:40pm
dave.s
hi Scarey, yes it is touch screen.
dave
Post #100448 5th Jan 2012 7:41pm
daveo
no yours is not the mk4 its a denso unit, fitted to the 2005/6 and on. there is no upgrade for that unit,, V8 facelift Range Rover Autobiography 22" wheels.
Post #100455 5th Jan 2012 8:11pm
dave.s
Hi Daveo,can the unit be changed or am i stuck with it, or can i get an updated disc
as seems to be a bit slow in reaction time.
dave
Post #100460 5th Jan 2012 8:49pm
you can get a 2009/2010 or 2011/12 discs...the first one is a firmware and mapping upgrade the second is just the mapping....there are pirate discs available but we cant discus that here or the proper ones cost around £150 from dealers. ... - .- -.
Post #100461 5th Jan 2012 8:58pm
dave.s
cheers Scarey, will keep my eyes open for a 2009/2010 disc or if someone has one for sale let me know.
dave
Post #100464 5th Jan 2012 9:17pm
