Home > Maintenance & Mods (L322) > Removal of rear Wiper/washer Motor: How To with Pics
Page 5 of 6 <123456>
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Ok. Took the plunge and just pulled the trim outwards as hard as I could. Came off with loud cracking noise but no broken clips Thumbs Up
All I did was change the non-return valve but that was easy. Didn't work at first as coincidentally(?) the nozzles were blocked. after a lot of faffing about: taking off spoiler, removing wiper spline cover and cleaning jets; put it all back together again and after a lot of running back and forth to check the jets were pointing in the right direction, all is good Thumbs Up
Thanks all for giving me the confidence to go ahead - especially the pics from RRUK Bow down 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #325928 4th May 2015 10:24am
bainbo1
2003 Range Rover Vogue Td6 Zambezi Silver
I had the same problem with mine found my rear wiper arm sticking in various positions, took motor apart very simple to dismantle no hidden surprises, found the white plastic cog was worn, this part is available on ebay, purchased the replacement cog fitted and re-assembled, the rear wiper works fine however, the problem is the cog must be slightly different to the motor gearing, as it will do a full wipe cycle but will not always return to the start position.
Anyone got ideas or fix for this one
Post #326835 9th May 2015 6:44am
destructimo
United Kingdom 2004 Range Rover Vogue 4.4 V8 Epsom Green
Hi All,
Thanks for the how to on this one. Thumbs Up
I was going to be lazy and get the garage to do this one, but it seemed straight forward enough so in the end I just ordered the new motor and had at it at lunchtime.
I put a piece of bubble wrap over the back section of the car roof to put the loose spoiler on and shut the ends in the rear doors to stop it flapping about too much (the bubble wrap not the spoiler).
Trim came off easily starting at one end and pulling straight (using the photos as a guide). It's been off before because one of the male plastic clips on the trim was bent over.
I was going to strip and re-seal the old motor as a spare or flog it as used / refurbed, but being a bit cack handed getting the wiper arm off, I managed to snap the plastic nipple off the end. Mad Never mind, on the spares pile it goes.
It all came off and went back together easily and the most difficult part of the whole job was getting the trim back on again. I struggled for a while but in the end I got the 2 ends attached to the mating panels, before starting at one end to clip it back in and it fell on. Shocked
So 30 minutes spent in the car park has netted a decent saving and more importantly the pure satisfaction of a fully operational rear wash wipe system.
Cheers
Clive
Post #368839 25th Jan 2016 2:39pm
CharlieBaja
United Kingdom 2007 Range Rover Autobiography TDV8 Buckingham Blue
Thank you very much for the helpful instructions with this job, very useful and lots of help. I only had a couple of isses and they were that the 12mm for the wiper was infact a 13mm and that once assembled for some mad reason the wiper caught the spoiler on its final sweep, however all sorted now and thanks again for the pictures and words.
Unnecessary quote removed
Post #401858 24th Aug 2016 6:41pm
Very chuffed that this is still helping people out Thumbs Up Discovery 4 HSE
Post #401927 25th Aug 2016 8:58am
crowebeard
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Thanks RRUK
Made the job a whole lot easier following this thread.
David David
2012 Range Rover Westminster 4.4TDV8
2004 Range Rover Vogue 4.4 V8 (LPG) (Not quite gone)
2021 Mazda CX-5
2003 Porsche Boxster
Post #455642 29th Oct 2017 8:24pm
MrSkill
I just had the rear washer stop working and then water down the inside of the rear window.
Trim came of quite easily with a firm straight pull.
Looks like I was lucky as it was just the pipe that had come off, pushed back in place, blew some air through the jet to ensure all clear and all good !
Nice to get an easy fix when you are expecting the worse!
Post #456320 6th Nov 2017 8:36am
johnb8538
United Kingdom 2014 Range Rover Autobiography SDV6 Fuji White
Great advice
Followed the guidance here and found everything working.... it was merely blocked nozzles!
Good to do it though and see that everything wasn't corroded.
Post #461279 18th Dec 2017 4:35pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
adara wrote:
The seal ring is inside the plastic piece here:
You have to remove the plastic part completely (it is thermally attached to the metal and inside you will find a 10x16x4 seal ring. After you replace the seal the plastic piece can be mounted easily back with 4 screws. It is the only critical area, where water under pressure must be contained.
I have just finished a refurb on my rear wiper motor after the gear stripped so thought I would add to this thread with a bit more info. The previous post advises fitting a shaft seal by removing the plastic water inlet. As this is plastic welded on it would need care to remove and then refitting is by self-tappers. I am sure it's a good fix but here is an option. On inspection from the inside, there is an o ring at the inner edge, the arrow in the quoted picture points to it. Mine had disintegrated and was the obvious reason for the leak and subsequent seizure. After trial and error, I found a 16mm x 9mm oring fits into the recess and seals against the shaft perfectly. I tried it up to 10psi and no leak. It takes a bit of teasing to get into the grove but easy enough and no need to interfere with the inlet. I have a bag of 50 if anyone in Perth wants one in the future. The replacement for the gear which was stripped I got from eBay however not the one listed for the L322. I discovered that a Mini Cooper rear motor gear is the same for half the price. I can confirm its a perfect match. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #477246 1st May 2018 5:12am
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Yay! More cheaper part crossovers and another fix.
Post #477278 1st May 2018 1:14pm
wayneg
A couple of pics to show what happens after the washer fluid has leaked into the gears and caused them to seize. The steel worm drive will still turn and strip the white plastic gear. Wiper still might move until it reaches the stripped section.
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #477334 2nd May 2018 5:03am
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
Yep mine was the same another legendary LR design. Done the plastic gear and mine still will not park so I reckon the little electronic PCB has proved water and electric don't mix. I rerouted my pipe and it now exits under the spoiler and does a reasonable job. TBH kind of like cleaning the wiper blade when it parks mid screen!
Post #477359 2nd May 2018 12:52pm
Tomo676
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Well, I stripped my rear wiper motor down, got the oil seal washer from e-@@y. put it all back together and it works great. Thanks for posting this thread, it's saved me ยฃ200. I am well happy.๐Ÿ‘๐Ÿ‘๐Ÿ‘
Post #493766 27th Oct 2018 2:55pm
DrRob
I need to remove my trim. What do folks mean by pulling it โ€œstraightโ€ to remove?
All tips to prevent tab breakage welcomed Bow down Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #522998 27th Jul 2019 4:30pm
Just pull directly towards you, away from the tailgate (given you are both in line)
The clips and fasteners are all roughly at 90 degrees to the tailgate, "straight" in .
Post #523000 27th Jul 2019 5:05pm
