![]() | Home > Technical (L322) > TD6 Chip |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
There are many chips & retunes available for the TD6. Stick to one of the more popular brands. Such as J.E. Engineering, Jeremy Fearn, DPchip, Chipit, Or this one
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 ![]() ![]() ![]() |
Had mine done recently.
Sorry to hijack this thread |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3757 ![]() ![]() |
no, but you will find that the Sports becomes superfluous due to the extra power - i.e. makes no difference |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
But do any of these put undue strain on the engine/gearbox...?
TD6 is a BMW engine and BMW did a power upgrade for it as std in the X5, its an understressed engine. The gearbox might be a different matter though! A lot depends how you drive it, if its balls out everywhere, and or a lot of towing then its life will be shortened!
Hi Paul
Bluefin:
Bluefin TDV8 chip:
Mine
Mine was done mobile by http://www.jfautomotive.co.uk/ The remaps are bespoke per vehicle. He downloads the original map and sends it to head office. They then enhance the map using your cars parameters instead of a generalised one for the car. I'm well impressed. Next one will be the TDV8. ![]() 99 Model 2.5 DSE Rioja Red / lightstone 97 BMW M3 Evo Convertible plus a few more! |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 958 ![]() ![]() ![]() |
how much do these things cost to do? and as well as increasing mpg does it mean that when cruising on the motorway do the revs / noise drop? ie i think at 90 the rev counter is about 4000? does it come down at all? as if it did then it would be quieter? that i think would be a real bonus? andy |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
Andy, it's not possible to get the revs to drop like that. The revs it pulls is determined by the gear ratios which is a mechanical element, not an electronic element. The only way you can get the revs to drop at a given speed (assuming you are already in the highest available gear) is to add a new gear. This also assumes the torque converter isn't allowing some slip at the time of course. |
m90got Member Since: 18 Oct 2011 Location: scunthorpe Posts: 120 ![]() ![]() ![]() |
does any one in the lincolnshire area fit these chips/maps Current Stable:
arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
see gary at td5 alive in grimsby, he mapped mine for me. pulls like a train. |
