Home > Technical (L322) > TD6 Chip
Brummy
Australia 2002 Range Rover HSE Td6 Java Black
TD6 Chip
Hi
I would like to fit a performance chip to my 2002 td6 HSE, can anyone recomend the best one around and also what is involved with fitting.
Cheers Paul
Post #94869 28th Nov 2011 11:35am
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
There are many chips & retunes available for the TD6. Stick to one of the more popular brands. Such as J.E. Engineering, Jeremy Fearn, DPchip, Chipit, Or this one
http://www.mybluefin.co.uk/
All have their advantages & disadvantages ( not much) Search this and other forums for more info as a lot have done it all before. I a'm yet to commit for my TD6 but am leaning towards the bluefin superchip
Gary
Post #94900 28th Nov 2011 2:02pm
rayc
United Kingdom 2007 Range Rover Vogue SE TDV8 Rimini Red
Had mine done recently.
All I can say is it totally transformed the car.
Drives really well and is quite "modern" feeling in the way it drives and it's willingness to accelerate.
Also fuel consumption has improved.
Very, very happy. Thumbs Up 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
99 Model 2.5 DSE Rioja Red / lightstone
97 BMW M3 Evo Convertible
plus a few more!
Post #94959 28th Nov 2011 8:43pm
Sorry to hijack this thread Smile
but do any of these affect the gearbox mapping at all?
Post #94960 28th Nov 2011 8:44pm
Vogue
no, but you will find that the Sports becomes superfluous due to the extra power - i.e. makes no difference
Post #94967 28th Nov 2011 9:16pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
But do any of these put undue strain on the engine/gearbox...?
I had a PSI power box on my P38 Diesel some hears ago and I;m sure it eventually lead to it's demise. Overworking the engine and blowing rad/head.
Maybe I;m wrong but if the engines were supposed to be like this why did LR "De Tune" them in the first place. Ash
2016 SDV8 AB
Post #94976 28th Nov 2011 10:04pm
Vogue
TD6 is a BMW engine and BMW did a power upgrade for it as std in the X5, its an understressed engine. The gearbox might be a different matter though! A lot depends how you drive it, if its balls out everywhere, and or a lot of towing then its life will be shortened!
There is also a big difference between a chip and a map, chips just dump extra fuel, whereas maps alter turbo boost pressure and other engine parameters, loads of info on here and on the interent in general.
Post #94979 28th Nov 2011 10:20pm
33CHINACARS
Hi Paul
PM sent Thumbs Up
Gary
Post #95004 29th Nov 2011 12:55am
Bluefin:
Land Rover Range Rover TD6
3/2002 - 6/2006
Engine type : Turbo-Diesel
Engine size : 2926 cm3
Cylinders : 6
Original bhp : 174
Original nm : 390
BHP increase : 28 (202)
NM gain : 136 (526)
Lb/Ft gain : 100
Big Torque Increase.....
Closing in on Standard TDV8.
Last edited by Gazellio @ Prestige Cars on 29th Nov 2011 7:36am. Edited 2 times in total
Post #95008 29th Nov 2011 7:30am
TDV8
Bluefin TDV8 chip:
Land Rover Range Rover L322 TDV8
3/2006 onwards
Engine size : 3630 cm3
Cylinders : 8
Original bhp : 268
Original nm : 640
BHP increase : 53 (321)
NM gain : 191 (831)
Lb/Ft gain : 141
832 Torques will blow your head off......
So who needs a 4.4.......
Post #95009 29th Nov 2011 7:34am
rayc
Mine
Quote:
Land Rover Range Rover 3.0 TD6 - Blue Optimized
Standard Power: 174BHP - 390Nm Torque
Blue Optimized Power: 212BHP - 475Nm Torque
This customer tows a twin wheeled caravan and drives down to spain a few times a year and was looking for a bit more Torque to help towing and more fuel economy, so we Blue Optimized it for him. Now he will have an extra 85Nm of torque and up too 15% better MPG
Mine was done mobile by http://www.jfautomotive.co.uk/ The remaps are bespoke per vehicle. He downloads the original map and sends it to head office. They then enhance the map using your cars parameters instead of a generalised one for the car.
I'm well impressed. Next one will be the TDV8. Thumbs Up 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
plus a few more!
Post #95010 29th Nov 2011 8:07am
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
how much do these things cost to do? and as well as increasing mpg does it mean that when cruising on the motorway do the revs / noise drop? ie i think at 90 the rev counter is about 4000? does it come down at all? as if it did then it would be quieter? that i think would be a real bonus? andy
Post #95315 30th Nov 2011 12:56pm
ric355
Andy, it's not possible to get the revs to drop like that. The revs it pulls is determined by the gear ratios which is a mechanical element, not an electronic element. The only way you can get the revs to drop at a given speed (assuming you are already in the highest available gear) is to add a new gear. This also assumes the torque converter isn't allowing some slip at the time of course.
Post #95385 30th Nov 2011 8:54pm
m90got
United Kingdom 2003 Range Rover HSE Td6 Alveston Red
does any one in the lincolnshire area fit these chips/maps Current Stable:
Range Rover 2003 TD6 HSE Alveston Red, Sand Leather
Ford Focus C-Max silver 2003
V/W transporter Blue 1995
Yamaha XJR1300 Yellow 2002
Kawasaki ZX7R Green 1998
Honda CBR 600 Black 1998
Yamaha RD125LC Mk1 Red 1986
Yamaha RD125LC Mk1 Blue 1986
Post #95388 30th Nov 2011 9:13pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
see gary at td5 alive in grimsby, he mapped mine for me. pulls like a train.
Post #95419 30th Nov 2011 11:57pm
