![]() | Home > Maintenance & Mods (L322) > HOWTO: Change Thermostat on '02 TD6 FFRR |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
@ richcl, stan and 666tur
Cannot find any mention of another "thermostat" . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Easier and cheaper chopping the EGR out of the equation altogether |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 ![]() ![]() ![]() |
Worth checking if your cars running too cool and an easy swap. A lot of info BMWland.co.uk
^^^^^ Excellent link 666tur |
Glad it was of use. Can't believe some guy bothered to create a CAD model!
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
I have the same problem as joe
It's a cheap and takes ten minutes, there is a useful video on you tube, search egr BMW 530d. If you have done the main stat I bet that's your problem. Do you monitor the temperatures on the hidden menu to see exactly what's happening?
@666tur
I was thinking the same, remove the fan and see if the noise is still there. I cant see how i could have damaged the fan itself, it went back on easily, cant imagine it was a cross thread causing the imbalance. I am wondering if I have damaged/bent the shaft of the water pump when I was struggling to get the fan off. It looked a bit tight down there to get the pump off, that will be another fun weekend. At least the fan should be easy to remove this time! 2012 4.4TDV8 VSE
Poped out the EGR Thermostat tonight only to find that it's passing air and doesn't return back shut once it warms up
Have you fitted the new egr stat yet?
It arrived tonight but I was late getting home
Update: seven months in from the thermostat changes I am again getting low coolant temperatures. After my 15 mile commute on a mix of rural and city driving I am only getting 76*c on the hidden menu readout. All I can assume is the main thermostat or egr thermal valve has failed again. Very annoying because its not a quick job, I will monitor but it looks like I will be doing it again but this time I think I will use genuine parts. 2012 4.4TDV8 VSE
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
Can some one tell me how I access the "hidden menu".
