Home > Maintenance & Mods (L322) > Final Stage Blower Resistor Replacement |
Last weekend I had to replace the blower resistor. It's a complete DIY job but needs lots of patients as you're up to your elbow in the dash with what seems like your arm bent in 5 places. Temptation to throw the little hedgehog across the drive runs high sometimes as you try and wiggle it in! Overall took me about 30 mins to get the trim panel above the pedals off, the panel inc wood off the trans' tunnel and get the old one out and the new one in and then put the trim back on.
16th May 2009 3:43pm |
StevieH Member Since: 05 Feb 2009 Location: Cumbernauld, Lanarkshire Posts: 117 |
Dan
17th May 2009 1:18am |
Monty Member Since: 06 Apr 2009 Location: Manchester UK Posts: 3 |
I bought mine direct from LR for under £20 probably worth checking with them. |
17th May 2009 12:53pm |
Bargain, which dealer was that from? Ottons in Salisbury wanted £75 + VAT when I rang them! Still hopefully this pattern part will actually be an improvement on the genuine one. |
17th May 2009 1:47pm |
Williams in Manchester 0161 232 5000 |
17th May 2009 5:20pm |
Well, as my unit failed after 9 months I'll be giving Williams a call as per above to see if they can still supply the part for £20!
11th Mar 2010 9:08pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
http://www.rswsolutions.com/index.php?opti...;Itemid=73
11th Mar 2010 9:12pm |
Thanks fella, when I did it the first time I figured it out the hard way, also I ended up cutting the ducting to get in there propperly.
11th Mar 2010 9:15pm |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
£20.67 for mine from LR in Kings Lynn.
15th Mar 2010 2:12pm |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 |
dan how did you no it had failed, did you check or did your battery go flat cheers[/quote] 02 Range Rover HSE Zambezie silver 4.4 |
15th Mar 2010 11:39pm |
Thanks, unfortunately the first one was from eBay rather than a main dealer. It's not too difficult to fit though to be honest. 30 mins really and that's 25 mins of removing the trim.
The first one failed at the beginning of last summer, I think because it sits in the air stream to stay cool the air was warmer in summer so it heats up and then fails. Basically when the fan should be on all of a sudden the fan will go off, but the blobs are all still lit up on the display. This exact same thing has happened now, on a frosty morning it will be fine, but if it's remotely warm then it doesn't work. |
16th Mar 2010 8:53am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6406 |
Here's my take on replacing the blower resistor
29th Apr 2010 12:43pm |
New car = new faulty blower resistor! |
20th Oct 2010 3:36pm |
Thats bad luck mate I thought you would have checked that little blighter |
20th Oct 2010 4:01pm |
