Home > General > LIST OF THINGS RECOMMENDED TO DO
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
Hi
I’ve just bought my V8 4.4 petrol/lpg RR 92k 3 weeks ago and even tho the dealer said its been service recently i thought i would do it all myself again just so i know its been done 100%
So I did
Plugs
Oil + filter
Air filter
Pollen filter
And also had to have a new header tank as the other 1 cracked which the dealer sorted for me
What other things would you recommend I do and check just so I now the car is in its best possibly conditions
Post #83862 26th Sep 2011 10:54am
bozmandb9
Re: LIST OF THINGS RECOMMENDED TO DO
dannyp15 wrote:
Hi
So I did
Plugs
Oil + filter
Air filter
Pollen filter
If it hasn't had an LPG service within 12 months, then get one done. If the gearbox oil hasn't been changed, then get that done. Maybe look at brake fluid. If you have access to a ramp then get it up on the ramp and check for corrosion underneath, treat it and waxoyl, whilst you're there check suspension components!
That enough to be going on with?
Thumbs Up Range Rover-less at the moment - Pining!
Post #83884 26th Sep 2011 1:04pm
Gearbox ATF and filter Whistle
Post #83896 26th Sep 2011 1:46pm
dannyp15
cheers for that 1 thing my friend is a auto gearbox mechanic and i asked him about the gearbox oil and he said leave it alone as he has had rr's in before for this and they have caused more problems. the reason why he said it will loosen any debris in the gear box which could then cause problems ... if is isn’t broke don’t fix it was his words... but i bet you i will get it done anyway lol
Post #83901 26th Sep 2011 1:59pm
Would you leave the oil in your engine for 93k miles without changing it? Add to that friction material in there as well! I would hope your answer is no. Look after your gearbox! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #83906 26th Sep 2011 2:41pm
dannyp15
very good point i will get it done as then i have peace of mind that its all nice clean oil in there .. is it a big job and what oil is needed and how much
Post #83914 26th Sep 2011 3:13pm
Wise choice! It's easy to do. I'm sure there is a how to in the wiki. It's about 6L of some special stuff. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #83925 26th Sep 2011 4:08pm
M44K TS
Check the PCV breathers too to make sure they're not split...
http://www.fullfatrr.com/forum/topic670.html 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #83954 26th Sep 2011 5:37pm
dannyp15
nice 1
just got home to take the ffrr for a spin and guess what flat batt Evil or Very Mad what a pain in the gary. do i change the batt and if so whats the biggest batt i can get in there which should give loads of batt power
gary (gary glitter = Censored )
Post #83993 26th Sep 2011 7:22pm
LostInSpace
New Zealand 2006 Range Rover Vogue SE Supercharged Java Black
Relatively new to FFRR ownership as well, on my list is the transfer box, is this the same as the transmission? 2006 Supercharged
1990 Porsche 928 GT
Post #83994 26th Sep 2011 7:25pm
swast4
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
Check for rust on rear quarters and rear arches and jacking points, especially rear. (search for rust found in search box)
Keep an eye on water level, don't ignore a loss of water, if loosing have a thorough look over all hose
connections, front and back, also look at water pump shaft for leaks.
Worth spraying some lithium grease on the steering column mechanism.
Check for oil leaks, the rocker cover gaskets are prone to leaks, have a feel around rocker cover for oil especially at the back where there is half moon shaped gasket (that you won't be able to see) Also sometimes the innner seal on the rocker cover near the plugs can leak putting oil down by your plugs, but you will have seen this is ok when you did your plugs.
Check for dampness in the boot area under the hatch of the boot on the rear passanger side, under here is the sat nav and stereo amp. Mine has been fine but otheres have had probs.
Check antifreeze strength is correct as it is an aluminium block and it needs to be 50%
Check the rear boot deck for rust and spray some wax or grease down the drain hole to help stop rust.
Gearbox oil change as mentioned & PCV valve and hose replacement along with oil seperator clean.
Last but no means least keep an eye on the forum as thier is alot of good info on here.
Enjoy.............
Post #83999 26th Sep 2011 7:39pm
dannyp15
nice 1 guys thanks for all your help on this keep them coming.. any idea on the batery Bow down
Post #84002 26th Sep 2011 7:48pm
swast4
These RR's and BMW suffer from a fault on the final stage resister, which sits in your heater ducting and when it goes faulty it leaves the blower on very low and because the car is sensitive to low voltages it will flatten battery. This is an easy fix - search for flatt battery, there is loads of info.
It could still be your battery though, best place at the moment is eurocar parts with 25% off get the biggest bosch battery, works out about 100 pound.
Anything that you need, do a search, there is loads of info.
Adam
PS love your RR in white
Post #84008 26th Sep 2011 8:20pm
dannyp15
cheers swast
is this the bad boy
http://www.eurocarparts.com/ecp/c/Land+Rov...amp;000020
thanks for the comments
Post #84024 26th Sep 2011 8:56pm
best battery available danny.. Thumbs Up ... - .- -.
Post #84026 26th Sep 2011 8:57pm
