Home > General > LIST OF THINGS RECOMMENDED TO DO
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
nice 1 Bow down
should i replace this as well as when i turn the car off this noise stays on behind the centre air vent
http://www.rswsolutions.com/index.php?opti...;Itemid=73
Post #84028 26th Sep 2011 9:00pm
swast4
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
Just replace the FSR if the fan is staying on, your battery may be fine.
Adam
Post #84065 26th Sep 2011 10:42pm
dannyp15
should i get from main stealer and does anyone have a part number Thumbs Up
Post #84096 27th Sep 2011 8:03am
you could get the part number from the online microcat, http://lrparts.net.ru/ ... - .- -.
Post #84100 27th Sep 2011 8:10am
dannyp15
part number from RR is JWL000010 £23 ALL IN
Post #84131 27th Sep 2011 9:54am
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
dannyp15 wrote:
cheers for that 1 thing my friend is a auto gearbox mechanic and i asked him about the gearbox oil and he said leave it alone as he has had rr's in before for this and they have caused more problems. the reason why he said it will loosen any debris in the gear box which could then cause problems ... if is isn’t broke don’t fix it was his words... but i bet you i will get it done anyway lol
I also heard this from a mechanic, but i took it to an auto transmission specialist who wasn't as mad as a box of frogs. Whistle __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #84669 29th Sep 2011 7:58pm
