![]() | Home > General > LIST OF THINGS RECOMMENDED TO DO |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1026 ![]() ![]() |
If it hasn't had an LPG service within 12 months, then get one done. If the gearbox oil hasn't been changed, then get that done. Maybe look at brake fluid. If you have access to a ramp then get it up on the ramp and check for corrosion underneath, treat it and waxoyl, whilst you're there check suspension components! That enough to be going on with? ![]() |
Gearbox ATF and filter |
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 ![]() ![]() ![]() |
cheers for that 1 thing my friend is a auto gearbox mechanic and i asked him about the gearbox oil and he said leave it alone as he has had rr's in before for this and they have caused more problems. the reason why he said it will loosen any debris in the gear box which could then cause problems ... if is isn’t broke don’t fix it was his words... but i bet you i will get it done anyway lol |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Would you leave the oil in your engine for 93k miles without changing it? Add to that friction material in there as well! I would hope your answer is no. Look after your gearbox! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
very good point i will get it done as then i have peace of mind that its all nice clean oil in there .. is it a big job and what oil is needed and how much |
Wise choice! It's easy to do. I'm sure there is a how to in the wiki. It's about 6L of some special stuff. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Check the PCV breathers too to make sure they're not split...
nice 1
LostInSpace Member Since: 28 Apr 2011 Location: Pulborough, West Sussex - ex NZ Posts: 107 ![]() ![]() ![]() |
Relatively new to FFRR ownership as well, on my list is the transfer box, is this the same as the transmission? 2006 Supercharged
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 ![]() ![]() ![]() |
Check for rust on rear quarters and rear arches and jacking points, especially rear. (search for rust found in search box)
nice 1 guys thanks for all your help on this keep them coming.. any idea on the batery |
These RR's and BMW suffer from a fault on the final stage resister, which sits in your heater ducting and when it goes faulty it leaves the blower on very low and because the car is sensitive to low voltages it will flatten battery. This is an easy fix - search for flatt battery, there is loads of info.
cheers swast
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
best battery available danny.. |
