![]() | Home > Maintenance & Mods (L322) > What type of jack do you use? |
Wow, all that fits in the back of the car for when you need to change a wheel at the roadside? ![]() Please guys, my point, there are safe places to lift the car from underneith, (when you dont have a two post/four post/four point lift available) that may be more suitable than the scissor jack provided by BMW. Ken, yes I've followed BBS from "the other" forum I find his posts technically interesting, but the touting I find poor form (unless of course he is forum sponser in which case that's fine I guess) ![]() |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 ![]() ![]() ![]() |
Guys guys guys!
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
Dan he is a sponsor on the Other side |
Adam it does in mine
That's the issue, finding a jack with enough lift. I don't want to spend hundreds of pounds on a full tilt workshop version, it shouldn't be necessary. Discovery 4 HSE
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2042 ![]() ![]() |
Ken
Nope caus I dont I use an Exhaust jack if required |
I've just gone through my owners manual AND the workshop manual, and neither of them state to put it into offroad height. They do say put it in Park, lock the steering column, chock the wheels and even put it into low range, but no mention of the suspension settings.
Adam different mans then I'll scan mine in
Yeah same issue, would need to remove the engine undertray which is simple but annoying. Wonder if a 4 tonne bottle jack would be better? Even though I have a flat concrete pad to do this on, the vehicle creeps as you jack it, bottle jacks don't like that! Discovery 4 HSE
Dan,
I forgot to take photo's of the front so I jacked it back up, but not all the way, the axle stands go up to the next peg, then the tyre is about an inch off the ground.... At that point the jack is at it's absolute maximum and near verticle. Dan ![]() |
