![]() | Home > General > Headphones & remote |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
sorry i cant help with your problem i just wanted to say update your car profile it helps for people to give you a more accurate answer |
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 ![]() ![]() ![]() |
Have you turned it on in the drop down menu on the nav screen?
barrieeld Member Since: 07 Dec 2010 Location: Scotland Posts: 260 ![]() |
Yeh tried turning it on from the nav screen i can get the driver rear to appear but the passenger rear doesn't go on at all?
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1022 ![]() |
It could be a loose wire, or it could be broken. I had a problem in my first S/C, it only came on sometimes, it was tracked down to a loose wire in the drivers seat. Range Rover-less at the moment - Pining! |
Is it a common fault? Its really strange cause the back of the car has never been used...i doubt they've seen 10 hours of usage ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35507 ![]() ![]() |
with the seat possibly going back and forth many times it could be a loose/broken wire...welcome to the joys of ffrr ownership.. |
The main harness that runs through the seat offen breaks down and is fibre optics so therefore is expensive... We keep them if you need one pm me...
