Home > General > Headphones & remote
barrieeld
Headphones & remote
Just wondered I'm on the lookout for 2x headphones and a remote for my vogue se, do I need to buy oem from landrover or can I get on eBay or salvage etc?
Also the passenger side rear screen seems to not want to come on although I'm sure I've done everything right on the nav unit...any suggestions as to what it can be?
Thanks in advance!
Post #82659 20th Sep 2011 6:02pm
pretlove
sorry i cant help with your problem i just wanted to say update your car profile it helps for people to give you a more accurate answer Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #82666 20th Sep 2011 6:52pm
rayc
United Kingdom 2007 Range Rover Vogue SE TDV8 Rimini Red
Have you turned it on in the drop down menu on the nav screen?
I think on mine you touch the tv / dvd icon for the rear. left and right have seperate icons. 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
99 Model 2.5 DSE Rioja Red / lightstone
97 BMW M3 Evo Convertible
plus a few more!
Post #82691 20th Sep 2011 8:09pm
barrieeld
Yeh tried turning it on from the nav screen i can get the driver rear to appear but the passenger rear doesn't go on at all?
Could it be a loose connection?
Post #82736 20th Sep 2011 9:23pm
bozmandb9
It could be a loose wire, or it could be broken. I had a problem in my first S/C, it only came on sometimes, it was tracked down to a loose wire in the drivers seat. Range Rover-less at the moment - Pining!
Post #82754 20th Sep 2011 10:13pm
barrieeld
Is it a common fault?
Its really strange cause the back of the car has never been used...i doubt they've seen 10 hours of usage Laughing
Post #82756 20th Sep 2011 10:15pm
with the seat possibly going back and forth many times it could be a loose/broken wire...welcome to the joys of ffrr ownership.. Wink ... - .- -.
Post #82783 21st Sep 2011 7:17am
The main harness that runs through the seat offen breaks down and is fibre optics so therefore is expensive... We keep them if you need one pm me...
Craig Thumbs Up
Post #82787 21st Sep 2011 7:35am
