Home > General > Headphones & remote |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
sorry i cant help with your problem i just wanted to say update your car profile it helps for people to give you a more accurate answer "RANGEISM WILL NOT BE TOLERATED"
20th Sep 2011 6:52pm |
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 |
Have you turned it on in the drop down menu on the nav screen?
20th Sep 2011 8:09pm |
barrieeld Member Since: 07 Dec 2010 Location: Scotland Posts: 260 |
Yeh tried turning it on from the nav screen i can get the driver rear to appear but the passenger rear doesn't go on at all?
20th Sep 2011 9:23pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
It could be a loose wire, or it could be broken. I had a problem in my first S/C, it only came on sometimes, it was tracked down to a loose wire in the drivers seat. Range Rover-less at the moment - Pining! |
20th Sep 2011 10:13pm |
Is it a common fault? Its really strange cause the back of the car has never been used...i doubt they've seen 10 hours of usage |
20th Sep 2011 10:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
with the seat possibly going back and forth many times it could be a loose/broken wire...welcome to the joys of ffrr ownership.. ... - .- -.
21st Sep 2011 7:17am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
The main harness that runs through the seat offen breaks down and is fibre optics so therefore is expensive... We keep them if you need one pm me...
21st Sep 2011 7:35am |
