Home > Off Topic > disc size |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35122 |
went to order some rear discs and was told that it could be 2 sizes that fit mine, 304mm or 354mm...now without physically taking of the wheel and measuring the disc ,is there any way of getting this info... ... - .- -.
19th Sep 2011 11:30am |
Search? I've asked this question Stan an think it's the smaller ones but you would have to check. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
19th Sep 2011 12:05pm |
Probably smaller on an older TD6. |
19th Sep 2011 12:08pm |
i'm thinking the smaller ones, but mine was a 'transition' from old to facelift but i'm thinking that was only the electronics [sat nav] that was upgraded.. ... - .- -.
19th Sep 2011 12:16pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Does microcat contain this info?
19th Sep 2011 12:45pm |
cant get the online one to take my vin and i havnt got the downloaded version on my laptop.. ... - .- -.
19th Sep 2011 1:09pm |
is there anyone with a downloaded version of microcat that can do a vin check for me to see if it tells you the rear disc diameter size .. ... - .- -.
19th Sep 2011 1:33pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
can you not measure to the nearest 50mm with the wheels on? 2004 black Vogue TD6 |
19th Sep 2011 2:40pm |
that means going outside..
19th Sep 2011 2:42pm |
hi mate, dont think there would be..i'm ordering of ebay at a very cheap price at £55.99 for 2 rear discs and pads so cant see any more discount there james..good thought though.. ... - .- -.
19th Sep 2011 2:48pm |
wheel off and it appears i have the 354m size... ... - .- -.
19th Sep 2011 3:14pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3121 |
wow, that's a great price! i was looking at £89! Who is that through? Can you PM me the link pls? |
19th Sep 2011 3:22pm |
pm sent.. ... - .- -.
19th Sep 2011 3:27pm |
The hub part of the smaller disc (where the wheel bolts up to) is straight and the larger discs have a smaller tapered end |
19th Sep 2011 5:31pm |
