![]() | Home > Off Topic > disc size |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 ![]() ![]() |
went to order some rear discs and was told that it could be 2 sizes that fit mine, 304mm or 354mm...now without physically taking of the wheel and measuring the disc ,is there any way of getting this info... ... - .- -.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Search? I've asked this question Stan an think it's the smaller ones but you would have to check. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Probably smaller on an older TD6. |
i'm thinking the smaller ones, but mine was a 'transition' from old to facelift but i'm thinking that was only the electronics [sat nav] that was upgraded.. ... - .- -.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Does microcat contain this info? |
cant get the online one to take my vin and i havnt got the downloaded version on my laptop.. ... - .- -.
is there anyone with a downloaded version of microcat that can do a vin check for me to see if it tells you the rear disc diameter size .. ... - .- -.
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
can you not measure to the nearest 50mm with the wheels on? 2004 black Vogue TD6 |
that means going outside.. |
hi mate, dont think there would be..i'm ordering of ebay at a very cheap price at £55.99 for 2 rear discs and pads so cant see any more discount there james..good thought though.. ... - .- -.
wheel off and it appears i have the 354m size... ... - .- -.
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3161 ![]() ![]() ![]() |
wow, that's a great price! i was looking at £89! Who is that through? Can you PM me the link pls? |
pm sent.. |
The hub part of the smaller disc (where the wheel bolts up to) is straight and the larger discs have a smaller tapered end |
