Home > Technical (L322) > 2011 4.4 TDV8 turbo spool sound on cold start
Benfelrr
United Kingdom 2007 Range Rover Vogue TDV8 Tonga Green
Evening everyone. I have had a look around online here and wider and cannot find anything on the following, but it might be I am using the wrong terminology when searching.
I have a 4.4 TDV8. I have noticed when on a cold start you can briefly hear what sounds like a turbo spooling (sort of whoooooooop) very quiet and subtle but it is there. (No other issues at all, idles nicely, pulls like a train when driving.)Then the sound stops as if an actuator has closed but there is no restricted performance warning etc. I am pretty sure it did not do that before. I need to get a mate to start when cold and listen at the back through the exhausts, but can anyone tell me if this is normal on these. Only car I knew to do this was the C5 RS6.
It is possible it always did do this, but I totally missed it if it does, so thought I would ask for any thoughts, experience for others, whether theirs does this too.
Many thanks,
Ben 2011 Range Rover Vogue 4.4 TDV8
2003 VW Golf V6 4motion
2001 Range Rover Vogue 4.6
1982 Range Rover in VOGUE
1990 Range Rover Vogue SE
2007 Audi A6 Avant Le Mans Quattro S-Line 3.0 TDI
2007 Skoda Ovtavia 2.0 TDI L&K
2007 GSX-R 750 K7
Post #714690 23rd Mar 2025 8:57pm
fuel burning heater ? ... - .- -.
Post #714693 23rd Mar 2025 9:40pm
Benfelrr
Ahhhh. I had not thought of that, thanks Smile 2011 Range Rover Vogue 4.4 TDV8
2007 GSX-R 750 K7
Post #714703 23rd Mar 2025 10:39pm
mjdronfield
The FBH is located in the front passenger wheel arch, sort of under the battery but in the wheel well. Its exhaust is down near where the front mudflap would go. Sounds a bit like a jet aircraft when it starts up….. should help you narrow it down. Heard better outside the car.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #714704 23rd Mar 2025 10:46pm
Benfelrr
Ah thanks. Yes hopefully it is that. No turbo sounds out of the exhaust so guessing it is that. Many thanks. It is certainly working. 2011 Range Rover Vogue 4.4 TDV8
2007 GSX-R 750 K7
Post #714717 24th Mar 2025 8:56am
