![]() | Home > Maintenance & Mods (L405) > Sharp crack sound as lower tailgate opens |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 99 ![]() ![]() ![]() |
Following - mine does exactly the same, has been for years.. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8509 ![]() ![]() ![]() |
Sounds like this may be your issue....!
Bikeracer Member Since: 24 Aug 2023 Location: Newark Posts: 17 ![]() ![]() ![]() |
Thanks for the replies, I'll have to investigate further to see what to do. |
Damn.... Thanks Haylands, seems like I have the curse of metal fatigue afterall...
Yep, just a big washer, the biggest you can get and it will live a few more years...
Thanks, I've had a look and can't see any cracking round the bolt, the noise seems to come from the middle of the drop down boot.
Don't think you would need the splits to make the noise, can you open and close the boot while holding the carpeted flap out the way to see what happens....? Pete
I've decided to let my local garage have a look for the problem because they'll have the tools and know what spare parts if any are needed.
Well, thanks again Haylands, and for those following this thread, I can happily confirm that after having added and significantly tightened down the somewhat large aluminium washer the sharp cracking sound is no longer.. Prior to adding the washer I had removed the entire pivot mechanism as well just to confirm that there's no further potential breakages on the pivot itself and happy to say that all still seems ok.. ![]()
Problem solved.
Glad you got to the bottom of it... |
