Home > Maintenance & Mods (L405) > Sharp crack sound as lower tailgate opens
Bikeracer
United Kingdom 2014 Range Rover Vogue SE SDV8 Nara Bronze
When I press the lower tailgate button to lower the tailgate there is a crack sound like snapping a piece of rigid platic in two just as it starts to open.
If I manually lift and push the tailgate to close it, then when I press the button to open and drop the tailate down there is no sound.
Any ideas?
Post #714475 20th Mar 2025 8:04am
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
Following - mine does exactly the same, has been for years..
Post #714480 20th Mar 2025 11:36am
Sounds like this may be your issue....!
https://www.fullfatrr.com/forum/topic66566.html Pete
Post #714481 20th Mar 2025 11:36am
Bikeracer
Thanks for the replies, I'll have to investigate further to see what to do.
Post #714485 20th Mar 2025 12:22pm
marcochezzi
Damn.... Thanks Haylands, seems like I have the curse of metal fatigue afterall...
Post #714499 20th Mar 2025 3:30pm
Yep, just a big washer, the biggest you can get and it will live a few more years...
Bikeracer, open the bottom part of the boot then lift up the carpeted trim that covers the gap between car and boot and on the left you will probably find the problem...
Thumbs Up Pete
Post #714506 20th Mar 2025 5:06pm
Bikeracer
Thanks, I've had a look and can't see any cracking round the bolt, the noise seems to come from the middle of the drop down boot.
There's what looks like a black plastic cylinder like some kind of actuator, one end is connected to the operating link seen in the pics posted, and also a white plastic pipe going from one side to the other in front of it. There are two plugs fastened to the carpet material on the underside but I could not get them unplugged so as to be able to lift the carpet part clear to get a good look.
Post #714515 20th Mar 2025 6:49pm
Don't think you would need the splits to make the noise, can you open and close the boot while holding the carpeted flap out the way to see what happens....? Pete
Post #714523 20th Mar 2025 7:42pm
Bikeracer
I've decided to let my local garage have a look for the problem because they'll have the tools and know what spare parts if any are needed.
Thanks anyway, I'll get it looked at next week and report back on what they find.
Post #714552 21st Mar 2025 7:59am
marcochezzi
Well, thanks again Haylands, and for those following this thread, I can happily confirm that after having added and significantly tightened down the somewhat large aluminium washer the sharp cracking sound is no longer..
Prior to adding the washer I had removed the entire pivot mechanism as well just to confirm that there's no further potential breakages on the pivot itself and happy to say that all still seems ok.. Thumbs Up
Post #714711 24th Mar 2025 5:12am
Bikeracer
Problem solved.
There are two plastic tubes, one from each side in the tailgate, I assume they're for the cables that stop the tailgate in the horizontal position and the cables can slide inside when the tailgate lifts to the upright position.
One of these tubes had twisted and when the button to lower the tailgate was pressed and the cable moved it made the plastic tube hit the taigate with a sharp cracking sound.
Post #714939 26th Mar 2025 3:04pm
Glad you got to the bottom of it... Thumbs Up Pete
Post #714995 27th Mar 2025 6:39pm
