Home > Technical (L405) > Cabin fumes...again.
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Ive read all the previous threads about FBH etc. causing cabin fumes, but mines different.
I drive normally with no problems whatever the temperature , but as soon as I slow to enter my lane, on occasions, I get a fuel/exhaust/burning smell into the cabin. I have talked to my trusty Indy, but he hasnt come across one of these yet. He suggested that if was a relatively short journey, even though it came up to temperature, could it be it be a failed regeneration of the DPF. I admit to not doing a long journey with sustained speeds for a while. Any thoughts. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #714101 15th Mar 2025 11:00am
D3Jon
Certainly there's a smell from the exhaust system when a DPF regen is occurring. Exhaust Gas Temperatures (EGT's) are raised to 600 degrees C+ and everything to do with the exhaust from the CAT backwards gets very warm indeed.
You would particularly notice it, if driving slowly or stopping mid DPF regeneration - which is sometimes unavoidable of course, especially if you don't know a regen is occurring! You're much less likely to notice any smell from the regen process if doing 70mph on a motorway, as the air flow is removing heat from surrounding components as well as any fumes.
But the smell (to my nose at least) during a DPF regen, is of a very hot exhaust, a 'sulphury' type smell, not diesel exhaust fumes or fuel smells.
If it's actual exhaust fumes you can smell, then it could be a leak in the exhaust system, or worse a leak in the exhaust link / cross over pipe. This can be an issue on the SDV6 engine, with owners complaining of exhaust fumes in the cabin.
I wonder if this could be the cause? I really hope not for your sake, as it's tricky to replace due to its location across the back of the engine. When they fail on Discoveries and RR Sports, it’s a body off job. Not sure will a Full Fat, perhaps someone else has experience?
Although on a more positive note, I've not personally heard of exhaust cross over failure on the SDV8!
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #714103 15th Mar 2025 12:04pm
GrandadRob
Thanks Jon. My car is SDV8. Sounds like the regeneration, my nose identification of smells may not be the best. Laughing 2013 SDV8 4.4 SE Luxor.
Post #714106 15th Mar 2025 12:10pm
Dolphinboy
I'm not convinced it's regen. I get it when coming to a halt for lights etc in town. I'm pretty sure there's no regen occurring at the time but will plug in my gap and monitor next time.
It's just had a major inspection and service by a very highly regarded Indie and they didn't spot any leaks.
Post #714108 15th Mar 2025 12:13pm
GrandadRob
Is there any way of knowing that a regeneration is occurring? 2013 SDV8 4.4 SE Luxor.
Post #714109 15th Mar 2025 12:16pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
https://www.fullfatrr.com/forum/topic60839.html
Have a read of this. Then get the Kot kit. I and many other use this to monitor the Regens SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #714111 15th Mar 2025 12:36pm
What’s the smell like.
I had a hot tar burning oil type smell. It was the Oil cooler. There is nothing that can't be fixed with a hammer😜😜
Post #714122 15th Mar 2025 3:13pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
I would be pointing at the oil cooler or the o rings on the back of it. That’s what was causing similar sounding issues with mine. New cooler and o rings fitted. Problem solved 2016 4.4 diesel
Post #714131 15th Mar 2025 5:24pm
andygts
another vote for oil cooler or turbo oil feed o ring out of the back of the cooler Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #714143 15th Mar 2025 8:28pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
I seem to have this too, but the oil cooler was replaced in March 2023, and the cars only done 16k miles since- it couldn't have failed again could it? 2012 SDV8 Vogue SE
Post #714146 15th Mar 2025 9:13pm
When they did the oil cooler did they do the o rings on the oil feed pipe at the same time? If not it could be those leaking. There is nothing that can't be fixed with a hammer😜😜
Post #714150 15th Mar 2025 10:12pm
Kot
Just done my oil cooler end of last month, and the turbo feed pipe Orings just before my warranty expired. Whistle
It was carefully steamed cleaned twice and belly pan cleaned each time, even then it took 2 weeks to burn off the oil that couldn't be accessed very well. Now smell has gone. Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #714164 16th Mar 2025 12:21pm
GrandadRob
If the oil cooler that was the cause, wouldn't I have an oil drip from underneath. My garage floor is clean. 2013 SDV8 4.4 SE Luxor.
Post #714169 16th Mar 2025 1:17pm
Kot
The belly pan holds quite a lot of oil before it starts leaking on to the floor, when mine started leaking I could smell it, but not 1 drop, till it really started to leak bad a few weeks later. 2018 SE SDV8 4.4 Byron Blue
Post #714201 16th Mar 2025 9:46pm
