![]() | Home > Technical (L405) > Cabin fumes...again. |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 511 ![]() ![]() |
Certainly there's a smell from the exhaust system when a DPF regen is occurring. Exhaust Gas Temperatures (EGT's) are raised to 600 degrees C+ and everything to do with the exhaust from the CAT backwards gets very warm indeed.
GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 238 ![]() ![]() ![]() |
Thanks Jon. My car is SDV8. Sounds like the regeneration, my nose identification of smells may not be the best. |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3214 ![]() ![]() ![]() |
I'm not convinced it's regen. I get it when coming to a halt for lights etc in town. I'm pretty sure there's no regen occurring at the time but will plug in my gap and monitor next time.
Is there any way of knowing that a regeneration is occurring? 2013 SDV8 4.4 SE Luxor.
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 488 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic60839.html
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8737 ![]() ![]() ![]() |
What’s the smell like.
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 196 ![]() ![]() ![]() |
I would be pointing at the oil cooler or the o rings on the back of it. That’s what was causing similar sounding issues with mine. New cooler and o rings fitted. Problem solved 2016 4.4 diesel |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 364 ![]() ![]() |
another vote for oil cooler or turbo oil feed o ring out of the back of the cooler Current
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1045 ![]() ![]() |
I seem to have this too, but the oil cooler was replaced in March 2023, and the cars only done 16k miles since- it couldn't have failed again could it? 2012 SDV8 Vogue SE |
When they did the oil cooler did they do the o rings on the oil feed pipe at the same time? If not it could be those leaking. There is nothing that can't be fixed with a hammer😜😜
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1306 ![]() ![]() |
Just done my oil cooler end of last month, and the turbo feed pipe Orings just before my warranty expired. |
If the oil cooler that was the cause, wouldn't I have an oil drip from underneath. My garage floor is clean. 2013 SDV8 4.4 SE Luxor.
The belly pan holds quite a lot of oil before it starts leaking on to the floor, when mine started leaking I could smell it, but not 1 drop, till it really started to leak bad a few weeks later. 2018 SE SDV8 4.4 Byron Blue |
