Home > Maintenance & Mods (L322) > Sill and rear wheel arch/jacking point repairs
Paddy X350
Ireland 2008 Range Rover Vogue TDV8 Stornoway Grey
Just finished repairing the rusty rear sills, jacking points and rear wheel arches on my 2008 3.6 TDV8. Others posts were a great help to me so thought I’d add my experience and a few snaps.
1. Rust was much worse that it initially looked. Prepare to find part so the inner sill and jacking point structure consumed by the tin worm
2. You can buy repair panels for inner jacking point, outer sill and outer wheel arch but you will have to fabricate many other internal bits as well as inner wheel arch sections.
3. It takes a long time if you’re a amateur diyer like me. This has taken me the best part of two months evening and weekends, although the right side which I did second took me a quarter of the time of the left side cause I knew a bit more about what I was at.
4. I am an amateur so the paint finish doesn’t look good in the daylight, but if he cars still going in a year I’ll get that redone by a pro.
5. Very doable for the amateur if you take your time. I’m a much better welder than I was when I started, you learn a lot.
So this is what I started with on the right, lots gone on the inner wheel arch as well
Some snaps at different stages through the process;
Inner and outer sill and jacking point cut/drilled out
Inner sill, new jacking point, outer sill and outer wheel arch, welding complete
Inner wheel arch needed extensive repairs as well, as far as the top of the wheel well. Very difficult to weld neatly when access is so restricted. In terms of forming the repair sections, this was the most challenging for me as they curve in at least two different directions. I quickly learned that trying to be too clever was not the way, make it up out of three flat bent bits of metal rather than trying to shape one!
[/img]
All painted and back together. I first applied 3 coats of epoxy primer, then filler, then sand, then three coats of epoxy, then 4 coats base, then three coats of clear coat… and even after my best efforts, it looks rough in the daylight….but its all metal under there!! Maybe I’ll get it redone by a pro in the future. All the best
Chris
Post #711091 5th Feb 2025 11:41am
Well done for having a go, it looks great, glad you got it sorted, I hope you have flooded the box sections with anti rust... also in the side panels of the boot there is space to get to the top of the rear arch and waste a bottle of antirust down there....... Thumbs Up Bow down Bow down Thumbs Up
FYI
The below were snorkel elbows I made, the finish is 10 coats of rattle can clear coat, then left a while, 2000 grit then polish, you can get a good finish but rattle cans just don't allow you to load it up so 10 coats works...!!!
 Pete
Post #711098 5th Feb 2025 1:18pm
toby1
Well done for having a go. It is not something I'd ever take on. 2012 Vogue TDV8 in Aintree green over sand
Post #711107 5th Feb 2025 2:25pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
That's come out well. In my view the final appearance is less important than the structural integrity, but having said that your finish looks pretty decent from the pics.
I've got to go through this in the not too distant future on my 2007 tdv8. Thankfully I'm a decent, self taught, welder so not phased by that part of it.
Metal shaping is quite an art but at the most basic level simple hand tools and ingenuity will get you a long way.
Chris
Post #711126 5th Feb 2025 4:43pm
Paddy X350
Thanks for that, good to know. Might have another go at it in a while. Need to drive the thing now!! All the best
Chris
Post #711168 5th Feb 2025 9:33pm
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Nice job and well done for tackling it Thumbs Up Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
https://www.youtube.com/@ChallengingClassics
Post #711217 6th Feb 2025 1:03pm
steve k
United Kingdom 2003 Range Rover HSE Td6 Giverny Green
Very nice and tidy - puts my repair to shame. One of those jobs that I will never, ever want to do again as like you it took forever to do both sides and yes the inside sections took the longest. This effectively means I'm stuck with mine now forever as it seems that every L322 succumbs to this problem eventually! Current: 2003 TD6 HSE. 161,000 miles
Previous 1993 Classic 3.9
Post #711800 14th Feb 2025 11:42am
