![]() | Home > Technical (L322) > locked out |
Bazzasglovers Member Since: 30 Nov 2024 Location: Leicestershire Posts: 3 ![]() ![]() ![]() |
I had this happen to me on an X5,put 12V onto number plate lamp via battery charger which give enough power to unlock doors.(this was with remote not key) |
essex boy Member Since: 21 Jan 2017 Location: essex Posts: 212 ![]() ![]() ![]() |
Im afraid its backed on to wall so no access to rear |
Not even a trailer socket within reach if there's one fitted?? |
No trailer socket |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7853 ![]() ![]() ![]() |
I seem to remember talk of using the side indicator connections but don’t know if true. Imagine they go through the light control module. Don’t know what you can get to underneath. I know it’s a pain to get to open the bonnet externally, obviously. When you do get in, fit a charging connector for like a CTEK and tuck it out the way where you can fish it out if needed. No help in your current situation I know….
I have a land rover indi locally will go there in the morning and see what they suggest or can do but thanks for replies |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 186 ![]() ![]() ![]() |
Lift offside side up, remove the under tray and put the charger on the starter motor electrical points, worked on my 2010 3.6 |
back in via jump leads from another vehicle and power to alternator then remote worked so very happy for easy job |
Excellent. Got there in the end.
