Home > Technical (L322) > locked out
essex boy
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
locked out
Hi all need to get drivers door open flat battery and key does nothing when turned any ideas gratefully
appreciated
Post #710851 2nd Feb 2025 5:28pm
Bazzasglovers
United Kingdom 2009 Range Rover Vogue SE TDV8 Alaska White
I had this happen to me on an X5,put 12V onto number plate lamp via battery charger which give enough power to unlock doors.(this was with remote not key)
Post #710852 2nd Feb 2025 5:36pm
essex boy
Im afraid its backed on to wall so no access to rear
Post #710855 2nd Feb 2025 5:56pm
Bazzasglovers
Not even a trailer socket within reach if there's one fitted??
Post #710856 2nd Feb 2025 6:00pm
essex boy
No trailer socket
Post #710857 2nd Feb 2025 6:03pm
mjdronfield
I seem to remember talk of using the side indicator connections but don’t know if true. Imagine they go through the light control module. Don’t know what you can get to underneath. I know it’s a pain to get to open the bonnet externally, obviously. When you do get in, fit a charging connector for like a CTEK and tuck it out the way where you can fish it out if needed. No help in your current situation I know….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #710861 2nd Feb 2025 6:09pm
essex boy
I have a land rover indi locally will go there in the morning and see what they suggest or can do but thanks for replies
Post #710862 2nd Feb 2025 6:16pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Lift offside side up, remove the under tray and put the charger on the starter motor electrical points, worked on my 2010 3.6
Post #710881 2nd Feb 2025 9:48pm
essex boy
back in via jump leads from another vehicle and power to alternator then remote worked so very happy for easy job
Post #710991 4th Feb 2025 7:19am
mjdronfield
Excellent. Got there in the end.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #711017 4th Feb 2025 12:18pm
