Home > Technical (L405) > Active stabilization fluid
Flyboy0902
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
Can anyone tell me the fluid i need to top up the reservoir..?
Post #710235 26th Jan 2025 2:05pm
JLR Cold climate power steering fluid, or oil to same spec. To see the level, shine a torch through the top...
If you need a lot to top up then you may have the dreaded pipe failure... Pete
Post #710237 26th Jan 2025 2:17pm
Flyboy0902
Thanks!
Post #710238 26th Jan 2025 2:21pm
Flyboy0902
Pics
Not sure if this normal or not, but the fluid is very brown and below minimum...
Also, the coolant level seemed low and dirty as well.
Do I need to be concerned, or just top up/drain and refill?
(see attached pics)
Thanks
Post #710514 29th Jan 2025 12:01pm
From memory the fluid is green.
LRN2261 Got - 2017 SDV8 Autobiography in Loire Blue
Post #710522 29th Jan 2025 12:35pm
Flyboy0902
Is the colour of the AS fluid correct/ish?
Post #710560 29th Jan 2025 7:25pm
As said it’s supposed to be light green
A good flush and refill would be a good idea… Thumbs Up Pete
Post #710567 29th Jan 2025 8:18pm
fisha
That brown fluid has water in it (or coolant). I'd definitely consider flushing it...
https://www.fullfatrr.com/forum/topic65671.html V8 or else ...
Post #710569 29th Jan 2025 8:40pm
Flyboy0902
Thanks guys.. Thumbs Up
Post #710588 30th Jan 2025 10:34am
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
There is a write up on forum on how to change out the fluid.
I did an addition to the thread where if you have two people to hand it is done in no time.
Post #710618 30th Jan 2025 8:13pm
Extol
United Kingdom 2016 Range Rover Autobiography SDV8 Carpathian Grey
If its help, I have used this oil and it seem to be the correct LR spec
https://www.ravenol-direct.uk/ravenol-ssf-...fluid.html
Post #711323 7th Feb 2025 2:04pm
sgorianin@gmail.com
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
I'm not a fan of genuine oils but honestly, hydraulic fluid as well as dif oils I think should be original.
When I had a problem with transfer case it was juddering on turns I changed oils twice with "LR spec" but problem was still there. After some articles and other examples on Internet I changed it with original LR and everything gone(coincidence? Maybe). But since I never used alternative for this systems.
STC50519 on Ebay £56 for 2 litres, which is less than £20 for ravenol...
Post #711732 13th Feb 2025 1:32pm
