![]() | Home > Technical (L405) > Active stabilization fluid |
Flyboy0902 Member Since: 27 Mar 2024 Location: Warwick Posts: 31 ![]() ![]() ![]() |
Can anyone tell me the fluid i need to top up the reservoir..? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8520 ![]() ![]() ![]() |
JLR Cold climate power steering fluid, or oil to same spec. To see the level, shine a torch through the top...
Thanks! |
Not sure if this normal or not, but the fluid is very brown and below minimum...
Is the colour of the AS fluid correct/ish? |
As said it’s supposed to be light green
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1457 ![]() ![]() |
That brown fluid has water in it (or coolant). I'd definitely consider flushing it...
Thanks guys.. |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 150 ![]() ![]() ![]() |
There is a write up on forum on how to change out the fluid.
Extol Member Since: 13 Jan 2024 Location: London Posts: 9 ![]() ![]() ![]() |
If its help, I have used this oil and it seem to be the correct LR spec
sgorianin@gmail.com Member Since: 11 May 2021 Location: London Posts: 36 ![]() ![]() ![]() |
I'm not a fan of genuine oils but honestly, hydraulic fluid as well as dif oils I think should be original.
