Home > Maintenance & Mods (L322) > M62 Vanos solenoid removal tool
jm1489
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Hiya Peeps!
Can anyone tell me where I can get the 32mm Vanos removal tool in UK. Loads of US sites selling them for £25-35 but then mahoosive postage costs? I have tried using a plumbers box socket cut down but just too tight on the solenoid body! Any help would be appreciated.
Post #710155 25th Jan 2025 3:22pm
Gsxr1250dave
You can buy them.off the bay but I had to machine mine a bit for a good fit or simply use a pair of pump pliers .
Post #710191 25th Jan 2025 8:43pm
jm1489
None on evilbay, what are "pump pliers"?
Post #710198 25th Jan 2025 10:26pm
Gsxr1250dave
https://www.ebay.co.uk/itm/265730101766?mk...media=COPY
Post #710200 25th Jan 2025 11:05pm
jm1489
I have those but don't want to damage the solenoid if possible, cleaning rather than replacing.
Post #710211 26th Jan 2025 9:34am
jm1489
Do you still have your machined tool?
Post #710212 26th Jan 2025 9:35am
Gsxr1250dave
Honestly give them a try their not that tight. I had the full timing kit when we did the chains and guides off the bay it did the job and I let my mate who did my engine rebuild keep it.
Post #710214 26th Jan 2025 9:51am
jm1489
As you say "not that tight" started to remove the solenoid.... slowly turning with the pliers.... started coming out..... 20 minutes later, still coming out..... another 20 minutes later, still coming out???? There isn't enough thread on the solenoid for it to take this long, could it be hung up on an O ring? On the BMW M62 there seems to be a secondary piece which needs to be fished out with a threaded bolt? Any ideas?
Post #710340 27th Jan 2025 4:20pm
Gsxr1250dave
Once you get it out you will need a threaded bolts for sure I'm trying to see if I posted about my rebuild
Post #710370 27th Jan 2025 8:30pm
Gsxr1250dave
Have a read of this
https://www.fullfatrr.com/forum/topic59412.html
Post #710371 27th Jan 2025 8:32pm
jm1489
Your write up left the solenoids untouched? There is a US Youtube with the bolt size. My issue is that the bloody solenoid body is turning but not coming out?
Post #710383 27th Jan 2025 9:07pm
Gsxr1250dave
Oh right wasn't sure. Yeah looks like the casing is just moving then if you have a go with yhe search function lots on here about removal and cleaning. Don't wast money on Ebay replacments they don't fit are complete crap .
I cleaned mine with brake cleaner and refitted them. There is an oil check valve and seal in there if you wanted to remove it for cleaning that's when you use the bolt.
A Google search will tell you what size deep socket you need to remove it. Look at the bmw forums.
Post #710385 27th Jan 2025 9:39pm
