Home > Maintenance & Mods (L322) > M62 Vanos solenoid removal tool |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 918 |
You can buy them.off the bay but I had to machine mine a bit for a good fit or simply use a pair of pump pliers . |
25th Jan 2025 8:43pm |
jm1489 Member Since: 09 Dec 2019 Location: Lincolnshire Posts: 48 |
None on evilbay, what are "pump pliers"? |
25th Jan 2025 10:26pm |
25th Jan 2025 11:05pm |
I have those but don't want to damage the solenoid if possible, cleaning rather than replacing. |
26th Jan 2025 9:34am |
Do you still have your machined tool? |
26th Jan 2025 9:35am |
Honestly give them a try their not that tight. I had the full timing kit when we did the chains and guides off the bay it did the job and I let my mate who did my engine rebuild keep it. |
26th Jan 2025 9:51am |
As you say "not that tight" started to remove the solenoid.... slowly turning with the pliers.... started coming out..... 20 minutes later, still coming out..... another 20 minutes later, still coming out???? There isn't enough thread on the solenoid for it to take this long, could it be hung up on an O ring? On the BMW M62 there seems to be a secondary piece which needs to be fished out with a threaded bolt? Any ideas? |
27th Jan 2025 4:20pm |
Once you get it out you will need a threaded bolts for sure I'm trying to see if I posted about my rebuild |
27th Jan 2025 8:30pm |
Have a read of this
27th Jan 2025 8:32pm |
Your write up left the solenoids untouched? There is a US Youtube with the bolt size. My issue is that the bloody solenoid body is turning but not coming out? |
27th Jan 2025 9:07pm |
Oh right wasn't sure. Yeah looks like the casing is just moving then if you have a go with yhe search function lots on here about removal and cleaning. Don't wast money on Ebay replacments they don't fit are complete crap .
27th Jan 2025 9:39pm |
