Home > General (L405) > Distance warning?
DaveBL405
United Kingdom 2019 Range Rover Autobiography SDV6 Balmoral Blue
Distance warning?
Does the L405 have any tech which checks the distance to the car in front and displays a warning on the dash or elsewhere if you’re deemed to be too close?
Post #709153 14th Jan 2025 9:31pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I can set a warning distance on my L405 should throw a green triangle on the dash showing active and you set warning by adaptive controls, as long as you have adaptive cruise then you definitely have it.
Post #709157 14th Jan 2025 10:05pm
comports
The Adaptive Cruise is great as it will also keep you the same distance from the car in front if active. I believe there are 3 levels.
If you have that, you will also have front rader which, when endaled, will give you an alert if you are getting too close under normal driving (not just under cruise control) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #709223 15th Jan 2025 5:07pm
at slow speed you have the parking sensors....at normal road speed i would just be alert a little more to avoid problems.. ... - .- -.
Post #709225 15th Jan 2025 5:12pm
comports
Agree Stan, but the front radar provides a warning for those moments you don’t realise… perhaps a momentary glance to change a radio station…
I believe the radar is also connected to the Intelligent Emergency Braking system - something I really want to test…… but am not brave enough. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #709232 15th Jan 2025 5:40pm
Kot
Ash try it,
enable it in the menu, and just carefully drive up to a vehicle at a round about, slow speed, no cruise active, no tailgater Whistle just be ready to brake yourself. It's actually very good, in fact it operates sooner than you might expect. I actually have disabled it around town as it is too sensitive for my driving style Cool
But I have used it on motorways, its excellent, but like anything else dont rely 100% on it, its there for Emergencies after all. And adaptive cruise, I guess, really removes the need for it. 2018 SE SDV8 4.4 Byron Blue
Post #709285 16th Jan 2025 9:20am
E500
The front collision warning thing doesn’t really sense distance, just warns you if the car in front is suddenly slowing and you haven’t got your foot on the brake already.
You can still tailgate people without it going off so don’t worry about that Laughing
Post #709299 16th Jan 2025 10:40am
Dolphinboy
I have activated this on my 'new to me' L405 and find it really useful. It even picked up a cyclist in poor light conditions before I saw him!
Post #709309 16th Jan 2025 11:43am
comports
E500, The collision 'warning' I get - and it has been very useful a couple of times for me but its just a red triange and noise to 'let you know' It doesn't perform any braking action at that point.
The part I'm s care to try is the Intelligent Emergency Braking where the car just takes over and brakes for you to avoid a collision. Kinda similar to the adaptive cruise but most likley more severe braking. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #709314 16th Jan 2025 12:08pm
E500
Yeah exactly. I’ve never let it brake for me either!
Post #709320 16th Jan 2025 12:23pm
DaveBL405
How did you configure this? Is it on all the time or only when you’ve got ACC on?
Post #709388 16th Jan 2025 10:18pm
comports
I’m not in the car right now but you enable front radar via the dash/steering wheel. Go into the menu and it under car setup I think.
Once it’s on it should always be active. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #709389 16th Jan 2025 10:34pm
supershuttle
My son insists I have collision alert activated before he lets me drive Rolling with laughter Geoff
Post #709390 16th Jan 2025 11:48pm
Kot
AEB
https://www.ownerinfo.landrover.com/docume...3/G2036373
Forward alert
https://www.ownerinfo.landrover.com/docume...1/G2123186
High speed collision alerthttps://www.ownerinfo.landrover.com/d...7/G2164215
Adaptive Cruise controlhttps://www.ownerinfo.landrover.com...5/G2123164 2018 SE SDV8 4.4 Byron Blue
Post #709395 17th Jan 2025 8:52am
