Home > General (L405) > Distance warning?
DaveBL405
United Kingdom 2019 Range Rover Autobiography SDV6 Balmoral Blue
Distance warning?
Does the L405 have any tech which checks the distance to the car in front and displays a warning on the dash or elsewhere if you’re deemed to be too close?
Post #709153 14th Jan 2025 9:31pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I can set a warning distance on my L405 should throw a green triangle on the dash showing active and you set warning by adaptive controls, as long as you have adaptive cruise then you definitely have it.
Post #709157 14th Jan 2025 10:05pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
The Adaptive Cruise is great as it will also keep you the same distance from the car in front if active. I believe there are 3 levels.
If you have that, you will also have front rader which, when endaled, will give you an alert if you are getting too close under normal driving (not just under cruise control) Ash
2016 SDV8 AB
Post #709223 15th Jan 2025 5:07pm
at slow speed you have the parking sensors....at normal road speed i would just be alert a little more to avoid problems.. ... - .- -.
Post #709225 15th Jan 2025 5:12pm
comports
Agree Stan, but the front radar provides a warning for those moments you don’t realise… perhaps a momentary glance to change a radio station…
I believe the radar is also connected to the Intelligent Emergency Braking system - something I really want to test…… but am not brave enough. Ash
2016 SDV8 AB
Post #709232 15th Jan 2025 5:40pm
