Home > eBay & Bargain Spots > electric car jacks
electric car jacks
better than a merc sprinter bottle jack?
3ton,
https://www.ebay.co.uk/itm/404719485578?_s...R87Gmb2HZQ
5ton,
https://www.ebay.co.uk/itm/156502688554?_s...R9bGmb2HZQ
Post #708448 6th Jan 2025 1:44pm
kevinp
I've got one similar to the bottom one which is very good.
Warning about the top one though. I had one and as I lifted the car it just buckled and snapped. SCAREY!!
Post #708463 6th Jan 2025 4:04pm
the 2ton one is very much like the OE jack supplied with the FF so i can imagine its rubbish.. ... - .- -.
Post #708474 6th Jan 2025 6:07pm
Do they go high enough. Funnily enough I just had my sprinter jack out while I was sorting my car stuff out. It’s a heavy bit of kit. If only we could get a proper top plate made for it then it would be useful on the 405. I do wonder if I could modify my 322 ally plate in some way…. There is nothing that can't be fixed with a hammer😜😜
Post #708496 6th Jan 2025 8:27pm
Stuart-
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
I am just trying to do a deal for some Sprinter bottle jacks. IIRC, someone makes the adaptor plate for the L322, does nobody make one for the L405 yet? 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #708523 7th Jan 2025 10:49am
the 5ton jack shown only goes up to 36cm/14inchs so not high enough? ... - .- -.
Post #708526 7th Jan 2025 11:10am
Gremlin500
Not electric I know, but has anyone used one of these? They often seem to be out of stock, 520mm seems good, but would still need an adapter for the L405. I use a big trolley jack for most lifting at home, but some jobs need a secondary jack, and a bottle jack is usefully compact to carry in the car for emergencies.
 “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #708527 7th Jan 2025 11:18am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
I've got a couple, a Merc Sprinter unit and a 20 Tonne HD unit, but nothing seems ideal.
Unfortunately the HD one doesn't go under the steps if the tyre is flat, so I need to put in to offroad mode to get the jack under the steps or use the scissor jack to get it to bottle jack height coz I'm not crawling under without at least 1 jack and I defo don't trust the scissor jack.
Considering an exhaust driven air bag right now as they are reasonably priced and pack flat, but no expereince of these, they use a similar bag for recoveries so may be some mileage in it and should avoid scrabbling in the dirt quite so much.
Anyone tried these, potentially they could be used via a compact compressed air can, similar to emergency tyre fix but without the slime ?
I need to be getting some Nascar air jacks Thumbs Up
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #708530 7th Jan 2025 11:43am
kevinp
I put mine on solid timber to get the height and improve the footprint on the ground. Thumbs Up
Post #708531 7th Jan 2025 11:44am
AndyRoo
Sorry forgot to put the link for air jack I referenced: but question is how to get a portable air line ?
&t=0s Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #708532 7th Jan 2025 11:49am
nbunney
I was looking at the same thing and came up with the same question about air Thumbs Up
Post #708540 7th Jan 2025 1:31pm
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
Be ideal if it was possible to rig up a connector to the car reservoir / air system
Post #708545 7th Jan 2025 2:30pm
Gremlin500
I got one of these PCL hose reels to connect my little compressor, it’s got 20m of self-reeling hose, dead easy to get out/put away:
Post #708549 7th Jan 2025 3:20pm
D3Jon
When out and about, I'd run it off a heavy duty portable 12v air compressor, like the sort the off-roading places sell. Would need to make up an adapter from the compressors tyre valve type fitting to PCL / Euro / XF or whatever air connector is on that thing.
The compressor can double up for tyre inflation duties as well - but more to carry around of course... I used to have a plumbed in air system in my 110 when I did a lot of off-roading in Australia. Sand driving, means you're always 'airing down' the tyres, so a good compressor is essential.
At home, I have a big compressor in the garage. But then I also have a 4T scissor lift, so there's no need for a jack when at home! Laughing 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #709369 16th Jan 2025 6:05pm
D3Jon
Re: electric car jacks
3ton,
I'd be a bit worried about the 3T one! I've had a LR factory supplied scissor jack strip out on me on first use (Disco 3).
The 5T one looks ok-ish, but as you've said has limited stroke.
I think for simplicity and not going to let-you-down, the Merc Sprinter jack wins every time though! Pun intended Laughing
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #709371 16th Jan 2025 6:12pm
