![]() | Home > eBay & Bargain Spots > electric car jacks |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35499 ![]() ![]() |
better than a merc sprinter bottle jack?
the 2ton one is very much like the OE jack supplied with the FF so i can imagine its rubbish.. ... - .- -.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Do they go high enough. Funnily enough I just had my sprinter jack out while I was sorting my car stuff out. It’s a heavy bit of kit. If only we could get a proper top plate made for it then it would be useful on the 405. I do wonder if I could modify my 322 ally plate in some way…. There is nothing that can't be fixed with a hammer😜😜
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 344 ![]() ![]() ![]() |
I am just trying to do a deal for some Sprinter bottle jacks. IIRC, someone makes the adaptor plate for the L322, does nobody make one for the L405 yet? 2017 4.4 SDV8 Autobiography in black
the 5ton jack shown only goes up to 36cm/14inchs so not high enough? ... - .- -.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1603 ![]() ![]() ![]() |
Not electric I know, but has anyone used one of these? They often seem to be out of stock, 520mm seems good, but would still need an adapter for the L405. I use a big trolley jack for most lifting at home, but some jobs need a secondary jack, and a bottle jack is usefully compact to carry in the car for emergencies.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 629 ![]() ![]() ![]() |
Hi,
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1272 ![]() ![]() ![]() |
I put mine on solid timber to get the height and improve the footprint on the ground. ![]() |
Sorry forgot to put the link for air jack I referenced: but question is how to get a portable air line ?
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2050 ![]() ![]() |
I was looking at the same thing and came up with the same question about air |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 67 ![]() ![]() ![]() |
Be ideal if it was possible to rig up a connector to the car reservoir / air system |
I got one of these PCL hose reels to connect my little compressor, it’s got 20m of self-reeling hose, dead easy to get out/put away:
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 498 ![]() ![]() |
When out and about, I'd run it off a heavy duty portable 12v air compressor, like the sort the off-roading places sell. Would need to make up an adapter from the compressors tyre valve type fitting to PCL / Euro / XF or whatever air connector is on that thing. The compressor can double up for tyre inflation duties as well - but more to carry around of course... I used to have a plumbed in air system in my 110 when I did a lot of off-roading in Australia. Sand driving, means you're always 'airing down' the tyres, so a good compressor is essential. At home, I have a big compressor in the garage. But then I also have a 4T scissor lift, so there's no need for a jack when at home! ![]() 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
I'd be a bit worried about the 3T one! I've had a LR factory supplied scissor jack strip out on me on first use (Disco 3). The 5T one looks ok-ish, but as you've said has limited stroke. I think for simplicity and not going to let-you-down, the Merc Sprinter jack wins every time though! Pun intended ![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
