Home > General (L460 2022) > New 460e owner - some hybrid questions/concerns
RSK21
Hi all
Long term L405 owner x 4 and D3/D4s various so have been around these boards a while
On December 23rd we took delivery of a P460 SE - Santorini with caraway and 22s but no Drug Dealer black bits Wink car has lots of kerb appeal, seems well put together and is wonderfully comfortable.
It’s our first hybrid and I am wondering how much we/the car are learning in these early, and clearly very cold, days.
On day 5 the car suffered two significant hesitations when pulling away from lights and very shortly afterwards went into limp mode. LR assist came out, squirted a few updates on it and it seemed to do the trick.
As an aside the car didn’t come with Pivi 4.2 which my Defneder got some months ago. It turned up last night and 4.21 has yet to appear - a bit surprised tha lt the dealer didn’t force the updates before delivery.
Anyway back to the driving and some questions for hybrid RR owners if I may ?
1 - Does yours struggle to stay in EV mode in the cold weather ? Ours does a few miles and then with even a relatively light extra bit of throttle once we get on to the main roads it switches out with a a bit of a rev into petrol and is quite reluctant to go back unless I cruise and then the below frequently happens …..
2 - ……there seems to be a strange retardant/rubber band effect at about 2k revs where it keeps thinking about EV vs petrol and occasionally goes EV for literally a few seconds and then back again. This can be very disconcerting at junctions but seems to be something that push of the accelerator fixes with a rev and a litch
Short version how smooth/seamless does your EV experience feel and should we expecting to just jump in and drive around on EV until the battery is flat or is it a constant in/out scenario ?
Part of me thinks it’s just a combination of car and driver learning plus the fallout from recent updates which came with a warning about EV performance as they bed in plus the cold weather.
For context I have just done a 13 mile journey in 0 degree temps after an overnight charge and a 30min electric precondition.
Car set off in EV and did 2.5 back road miles on EV, then getting on to A road under what I would say was moderate acceleration it switched to ICE. It remained on ICE all the way other than brief flickers into EV at traffic lights and when crossing off throttle. Total journey 13 miles at average speed of 45mph and supposed 36mog efficiency
Any and all observations gratefully received
EDIT TO ADD - Have just set off on another test run, car started on EV for a very short distance, then ICE kicked in under light acceleration and now cannot select EV at all with the “EV temporarily unavailable” message in the dashboard - starting to think I might have the heater matrix issue I have been reading about …..
Post #708244 4th Jan 2025 10:03am
Japseroony
England 2019 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Sorry can’t help with the EV issues having only borrowed one of the early RRS versions a few years back (I thought it was dreadful) but on the Pivi Pro side the dealer cannot force the updates and the car will just update itself over time Thumbs Up "UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #708246 4th Jan 2025 11:07am
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Have a look at my post about HV heater. I’ve got a p400e and it’s one of those faults that you don’t really know what’s wrong until it’s fixed!
Mine has a new one on and will run on EV (provided I don’t ask for too much power) until the battery is dead. I’ve noticed now we’re in minus temps that it sometimes runs for the first half mile or so before going back to normal.
An easy test is to turn off the cars heater completely. The HV heaters purpose is to heat the cabin using battery, rather than the engine. The car should run freely in ev mode with it off. If you turn the heater back on whilst driving and the engine starts, then your heater has failed. Mine gave no faults on Icarsoft so this is the only way you’ll know for sure.
Loads of people must be driving round, unaware that it’s even a fault, just thinking that this hybrid malarkey isn’t much good! My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #708249 4th Jan 2025 11:15am
RSK21
Ta - after all these years I didn’t know they couldn’t pre-empt it.
Now the wait for 4.21 !!
Post #708269 4th Jan 2025 3:54pm
RSK21
Thanks v much for the detailed response
It doesn’t seem to be that, or at least the climate on/off seems to make no difference.
I am starting off in EV but it is lasting minutes before locking into EV and the “EV temporally not available” message appears when I try to force it back.
I am also noticing that even a very small throttle input or even an incline is causing EV to drop. It switches to EV at sub 20mph and then just won’t go back and yet I am sure I have read people managing 50mph and upwards on full EV and completing whole journeys.
All I can do is restart the car, and then the cycle repeats.
I have been on a couple of 30 mile runs today and no EV available after minutes on each. The car and engine are warm as a result but the battery doesn’t seem to want to play for any length of time at all.
Currently it seems as I have just a P as opposed to a PHEV !
Could I ask to you to clarify this bit ?
“I’ve noticed now we’re in minus temps that it sometimes runs for the first half mile or so before going back to normal.”
Do you mean it runs in ICE for a short while in cold temps after starting and then flicks to EV or the other way round ?
Thanks again
Post #708271 4th Jan 2025 4:02pm
Lev
Estonia
Best way to check if your HVHC is broken is using electric pre-cononditioning. If your car gets warm with electric pre-conditioning, it's something else. If electric pre-conditioning is blowing cold air - your HVHC unfortunately needs (another) replacement.
Post #708281 4th Jan 2025 7:01pm
RSK21
Thanks
Have tried that and all is well
Just had a visit from LR assist
He confirmed that the hardware is all fine but the system is throwing a coolant error which!is what it showed previously but his colleague cleared with a module update last week.
It would seem that the reason for the low EV performance / almost immediate switch to hybrid and non possibility of switching it back on unless rebooting the car, is because the car thinks the EV system is going to overheat and so locks it out.
Faulty software or sensor is his best guess
Car goes into dealership on Monday …….
Four L405s, one D3, three D4s and a new Defender and this car has matched my total LR Assist calls covering all of those in its first 10 days !
Post #708287 4th Jan 2025 7:25pm
Lev
Estonia
I'm very unhappy about me choosing PHEV over petrol version. I think it will give me nothing but increasing PITA over the years. I was initially planning to keep this car for 10+ years, but I'm getting an increasing temptation to get a rid of this crap ASAP for whatever cost just to minimize the damage.
Post #708289 4th Jan 2025 7:33pm
RSK21
I have seen your posts over the on the US forum and it’s pretty clear you are unhappy.
We went for PHEV as, assuming it works, it is perfect for our use cases given my wife will drive it on local trips the vast majority of the time. We have friends who have RR and RRS hybrids and they are very happy with them and their performance.
I am hoping that the issues we have currently will be fixed and we’ll be just as content.
Let’s see.
Post #708291 4th Jan 2025 7:41pm
Lev
Estonia
I really hope you'll get your issues fixed and everything will be fine. Maybe it's just northern climate I live in.
Post #708292 4th Jan 2025 7:48pm
hoppy_70
Thanks again
Sorry yes, engine for a minute or two then normal EV My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #708299 4th Jan 2025 8:15pm
EdJ
To the OP, I’ve never had any of the issues you have described. In contrast to my previous P400e, my P550e stays in EV mode, even if I put my foot down or in very cold temperatures. 2024 Range Rover P550e AB
Post #708392 5th Jan 2025 6:19pm
Pixelpower
United Kingdom 2005 Range Rover Vogue Td6 Santorini Black
Something is wrong there. MY 460e in EV mode will run the battery dry unless you go mad with the accelerator. I've done 1500 miles in mine and only had the engine on for around 200 of those. All my local commuting is battery. Having previously had 2 EV's is suits me perfectly. 1 mile per KWH isn't great, but the refinement you get makes up for it.
Post #708411 5th Jan 2025 9:19pm
JackRegan
My experience is the same as Pixelpower's 2024 P550e Autobiography
2016MY TDV6 Autobiography - Gone
2011MY 5.0 SC Autobiography Black - Gone
2005 TD6 Vogue - Gone
Post #708433 6th Jan 2025 10:34am
Eirik34
Norway
Same here, our P550e runs on EV until battery is empty. Occasionally - if the ICE hasn't been used for weeks - the ICE kicks in even in EV mode, but after a few kilometers it goes back to pure EV mode again.
I tested a MY23 P510e two years ago, and that car had a similar fault: was not able to run longer distances ( > 10 km) in pure EV mode, even if the battery was fully charged. L460 P550e AB SWB MY24
Sold: L322 TDV8 Vogue MY07
Mini Cooper S Convertible
Post #708442 6th Jan 2025 12:04pm
