![]() | Home > General (L405) > Rear passenger floor wet with wiper fluid |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1457 ![]() ![]() ![]() |
Evening Toghrul,
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1644 ![]() ![]() ![]() |
Maybe where it does the “dog leg” joint above the “B” pillar leaking? That would run down the B pillar probably into the rear passenger footwell? Time to pull some headlining trim, and inspect, methinks?
Kellen Member Since: 16 Dec 2024 Location: Seattle Posts: 12 ![]() ![]() |
You sure it’s washer fluid? I’d also make sure your drain pipes are clear and not rusted. |
Toghrul Member Since: 14 Feb 2024 Location: Bern Posts: 2 ![]() ![]() ![]() |
Thank you for your valuable comments.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1304 ![]() ![]() |
Do you have a sunroof? |
