Home > General (L405) > Engine failure £13,000
D3Jon
Mikey wrote:
The 2.0 Ingenium is fitted to the 405, in petrol guise
While they seem to be much better than the diesel variant, that may be down to volume sold...
Fair enough, didn't think of that, was really thinking of the diesel variants! But good call Thumbs Up 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #707718 27th Dec 2024 10:53pm
Gremlin500
ChrisJC wrote:
The problem is when the Ingenium is mounted transversely in the Disco Sport / Evoque. There isn't enough room to mount the DPF where it needs to be, i.e. right on the exhaust manifold.
So it doesn't work as well, and hence the oil dilution.
Not a problem on 'proper' vehicles, like Range Rover and Jaguar.
Chris.
Sorry Chris, but for the record, the latter comment is simply incorrect: JLR have consistently mounted vehicle DPF’s too far downstream of the exhaust manifold in several vehicles, including the L494 and L405 as well as the smaller siblings you mentioned. Dilution can be a problem in any diesel JLR product.
However, I would say that the dilution algorithm can often overestimate dilution level. Based on testing oil samples in my own TDV6, dilution increases about 1% per 2500 miles mostly urban driving. I tend to change oil at this interval, since it coincides with 6months of driving for me. One caveat is that I monitor regens in almost an OCD way and rarely have an aborted regen. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #707719 27th Dec 2024 11:18pm
V8 Bob
Remember reading that the cat problems wre worse where the engine was transversely mounted which forced the positioning further down the exhaust.
A friend has a D5 with the straight six engine has experienced (amongst other issues! ) failure of the alternator drive belt which doubles up as the hybrid power source drive. I believe that this is a poor elm across all ingenum powered cars.
Unfortunately it is not just JLR who has problems designing a reliable engine ….look no further then the Ford eco boom! A wet belt engine where the timing belt runs inside the engine sump and breaks down with the oil which often leads to premature failure. Replacement is also expensive circa £1,000 +. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #707726 28th Dec 2024 8:27am
caymanblack
Vogue wrote:
I’m probably not going to be popular with this - but i would (and did) avoid anything with an Ignium engine in it - I went for the last of the V8 Diesels and would do exactly the same again - I’m on my 3rd V8 Diesel and everyone has been faultless - absolutely no chance repeating that reliability record with any Igniboom engine.
If I couldn’t have bought an SDV8, it would have been
A 5.0 petrol - it’s as simple as that 👍🏻😃
Feel the same if I was to change it would be the 4.4 BMW Engine or the supercharged V8. overfinch modified
Post #707741 28th Dec 2024 11:55am
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
My tuppence worth (and has served me well) is if you own a diesel RR you must learn how to change the oil and filter yourself irrespective of dealer servicing (which should be done alongside your own oil changes for waranty support). I change my RR oil every 3 to 4k miles with quality oil and filter. It costs me circa £75 plus an hour of my time. The oil pump is a manual one from amazon costing £45 but there are plenty of manual and powered options.
I enjoy driving knowing my oil is able to do its job and protect my valuable running gear. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #710843 2nd Feb 2025 3:57pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, I've had experience of this with a Mazda in the past, it's pretty much common to all DPF based diesels with the diesel injection regen process and since then I have always changed the oil every 5000 miles.
Also I'm lucky in that I have 2 cars, I use the Micra for shopping trips etc. Anything less than a few miles, which means I'm not exposing the fatty to too many part regens so fuels not getting in the oil in the first place.
Unfortunately my own OCD does not really protect me from a previous owner, who likely having the car from new and under warranty probably took no such precautions and so by the time I come to buy it 3 years old, the damage could already have been done and it's just a matter of time before the kaboom.
It's also one of those paradox scenarios, where you'd really want a low mileage lightly treated car but in actual fact, it would be the higher mileage harder driven car that is likely in the better condition engine wise.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #710853 2nd Feb 2025 5:41pm
V8 Bob
Has anyone wrapped the exhaust manifolds/pipe to maintain the temperature to aid the dpfs efficiency? We used to do it on rally cars to take temperature away from the engine bay so should help especially where the dpf is fitted further back on the exhaust. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #710904 3rd Feb 2025 9:43am
D3Jon
Good shout V8 Bob,
When I was into Westfield kit cars, ceramic coating was a popular thing to do as well as exhaust wrapping!
IIRC, one company was Camcoat who would ceramin coat exhaust manifolds / downpipes. The exhausts would be so cool, you could touch them even after driving hard. Pushes all the heat down-stream.
By the way, there's a V8 Bob on the Westfield forum, used to own a SEight like mine - not you is it?
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #711092 5th Feb 2025 10:55am
V8 Bob
No not on Westfield forum although I have often considered building one! Used user name since I had a classic V8 Range Rover. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #711144 5th Feb 2025 5:53pm
D3Jon
2014 Disco 4 HSE
Post #711192 6th Feb 2025 9:16am
dhallworth
We've had a Discovery Sport Hybrid courtesy car for almost a month now.
It's a 3 cylinder, 1.5 litre Turbo Ingenium engine assisted by a battery that gives around 25 miles EV only range in a perfect world.
The 3 cylinder makes 200bhp and the motor adds 100bhp. Whilst it goes pretty well and corners nicely, it's definitely not a car I'd buy.
A 1.5 litre 3 cylinder turbo making 200bhp isn't something that I can see lasting that long, especially when it's got "Ingenium" written on the cover. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #711251 6th Feb 2025 6:28pm
harisson
Switzerland
.. in the beginning of the thread there was a misunderstanding about the technology (what is Ingenium?)
as an owner, which had the Lion and now the Ingenium, I would like to clarify quickly Smile
in the RR/RRS there were:
- V6 Diesel
- V8 Diesel
from end of 2020/beginning of 2021 JLR launched the Ingenium Diesels as:
- Inline 6 with MHEV
- Types: D250, D300, D350
The number is similar to the horse-power
until now neither I read nor experienced anything about oil dilution or engine outages in the Ingenium Diesel area.
besides that the Ingenium Diesel is maybe one of the most modern Diesel engines on earth now, I would like to shortly focus on the DPF architecture:
the significant difference is the mounting of the DPF (and CAT) directly to the turbo outlet. The DPF of the V6 Lions was far away from the engine and therefore during normal driving conditions had lower temperature (which leads to more active regenerations)
the only negative point about the Ingenium is the extended oil service intervall: 2Y or 34000km
Me, personally will change the oil every max. 10'000km by the vacuum method by my own. Every 2Y I will let JLR do it, so that I have a proper service history in OSH.
I have now 40'000km on the ODO and have done oil changes at 4000, 17000 and 33000km
additonally I try to fill up only FAME-free Diesel (e.g. BP Ultimate Diesel) to avoid Bio-Diesel... Range Rover Sport HST D350
Post #711736 13th Feb 2025 1:43pm
