Home > Maintenance & Mods (L322) > A sobering thought - oil related
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
A few assumptions,
16000 miles between oil changes (LR recommendation I believe)
Average 35 MPH (you will be surprised how low your average is)
That’s 457 hours driving (haven’t factored in anything for standing still!!)
That’s 27400 minutes
1600 RPM (assumed average)
Your engine has completed 43 million 840 thousand revolutions
Our 4.4 TDV8 has big timing chains crushing our oil on top of your typical engine components putting our oil under extreme duress.
It makes me question my 3k to 4k oil changes and I use top quality oil without fail….. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #706964 15th Dec 2024 5:23pm
Kot
oil is cheap, engines are not 2018 SE SDV8 4.4 Byron Blue
Post #706969 15th Dec 2024 5:36pm
Eastsoutheast
Love the colour of your car kot. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #706974 15th Dec 2024 6:22pm
Kot
Its looking very grey at the moment needs some tlc Smile 2018 SE SDV8 4.4 Byron Blue
Post #706984 15th Dec 2024 7:54pm
JayGee
The oil is not under extreme duress in these low revving engines. JLR oil change intervals are too long but 3-4k is overkill as is premium oil IMO. Soot load and fuel contamination are the reasons to change the oil. 2012 TDV8 Vogue (L322)
Post #706988 15th Dec 2024 8:17pm
Eastsoutheast
JayGee, to say you’re more knowledgeable with these cars than me would likely be the understatement of the year so I know you are right.
3k to 4k miles for me is 2 oil changes a year and at £100 for premium oil and filter it’s only costing me an extra £100 per year. Don’t get me wrong, on my salary now having left a lucrative career behind me £100 is not chump change but it gives me peace of mind. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #706998 15th Dec 2024 9:52pm
D3Jon
Re: A sobering thought - oil related
Eastsoutheast wrote:
<SNIP> Our 4.4 TDV8 has big timing chains crushing our oil on top of your typical engine components putting our oil under extreme duress <SNIP>.
Interesting - do you have any links discussing timing chains and their detriment to oil?
I always thought (perhaps wrongly Smile ) that the big-ends were the oil crushing dept. of an engine?
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #707324 20th Dec 2024 11:55pm
Eastsoutheast
I spend far too long watching you tube videos especially vehicle related but trying to locate would be quite the mission (I will try). The motor oil geek does cover this subject and his content is very informative and avoids the typical anecdotal bull. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #707343 21st Dec 2024 8:58am
JayGee
Jon
Oil shear is where the long chain molecules that extrend oil viscosity range are chopped up in gear and chain meshing but as these engines have low viscosity range oil it's not an issue. Oil film strength is important for plain bearing surfaces like crank bearings and cams but this is principaly down to oil base stock quality which remains stable over time but which can deteriorate with fuel dilution. These engines are very robust so there is no need for undue anxiety over this and <10k mile oil changes with the correct oil will ensure the engine outlasts most other components on the car. 2012 TDV8 Vogue (L322)
Post #707347 21st Dec 2024 10:03am
D3Jon
Thanks JayGee & Eastsoutheast. Smile 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #707352 21st Dec 2024 11:31am
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
The Motoroilgeek will ask: do you have any data supporting your idea?
Note: your piece of mind isn't oil data Wink
Not saying you shouldn't change it if driving with 'old oil' makes you unhappy.
Your unhappiness may actually be measured (data, science) but, as they say: "Correlation does not imply causation."
One could learn to accept, based on data, modern oils CAN take the beating and one can HAVE piece of mind using modern oils and spend the £100 on something ELSE.
Just my £0,02. 2012 4.4TDV8
2000 Honda S2000
Post #707430 22nd Dec 2024 12:34pm
Eastsoutheast
?si=cJaI549u58Qnuln0 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #708352 5th Jan 2025 12:53pm
JayGee
Rolling with laughter
Diesel vs Petrol engines?
How the car is driven?
Oil shear?
Type of oil in terms of viscosity range?
Detergent and addative package in the oil?
Oil dilution from DPF regeneration?
Existing engine wear when you get the car?
How does synthetic oil give you extra mileage if the oil change is only about contamination? 2012 TDV8 Vogue (L322)
Post #708368 5th Jan 2025 2:30pm
Eastsoutheast
I posted as I had previously advised I had watched so many videos I couldn't easily find again, this was one of them hence sharing. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #708376 5th Jan 2025 4:46pm
SpitfireS
A real engineer Wink would start the video with:
"To find out how long you can use your engine oil based on your type of car and the conditions you use it in you take a sample after, lets say, 10000km and send it in for analysis." 2012 4.4TDV8
2000 Honda S2000
Post #708435 6th Jan 2025 10:56am
