![]() | Home > Maintenance & Mods (L322) > Rust Found - Please clean your arches today - Preventable |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
A stitch in time saves nine. Once it starts you have to keep on at it. Once the rust has been sanded off and the arch repainted it might be worth waxoyling and cleaning/re-doing regularly. Maybe better to try for a decent finish before the winter and road salt etc really get going. Only Range Rovers since 1988 |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Any tips on where to squirt some Waxoyl?
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1458 ![]() ![]() |
I had read on an Jag XK8 thread that the sills were prone to rusting in a similar fashion and a number of people drilled a hole in the sill which allowed them to inject waxoyl on the inside of the sill and then closed it up with a bung. V8 or else ... |
Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73 ![]() ![]() ![]() |
Marshalls quoted me £600 which seems a bit steep! |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 903 ![]() ![]() ![]() |
When you remove the lower plastic side sills there are several holes you can use to spray into and reach all the internal areas - I use Dinitrol products which I’d recommend 👍 |
