![]() | Home > Technical (L322) > 4.4 TDV8 Injector Removal |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3201 ![]() ![]() ![]() |
I'm guessing nobody has had to replace an injector on the 4.4 then |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1234 ![]() ![]() ![]() |
I could be way off target here, but is this any use? - very little info on the web is seems, the only videos I found were not helpful at all.
Cheers Merchy,
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
I presume you have watched this video? https://www.youtube.com/watch?v=2_A4su7rSyU
Mikeerhymes Member Since: 01 Sep 2018 Location: Manchester Posts: 28 ![]() ![]() ![]() |
Hi David, how did you get on, any tips? |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 904 ![]() ![]() ![]() |
Wayne is bang on the money, when I had some injector woes last year, we removed all 8 and sent them off to Colchester for inspection and cleaning
at 20 mins and 30 secs into the video you can see the struggle that he is having with injector 8 |
I've not done the job yet. Removing the covers over the injectors looks to be a horrendous job. There's 7 nuts on them and they look almost invisible from the top. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 146 ![]() ![]() ![]() |
On the 3.6 which has issues getting 4&8 out, my indy said they use a ratchet strap and hoik the engine over to the side to give a few mm of wiggle room. Not sure what they attach it to though. |
Kiwi RR Member Since: 02 Mar 2025 Location: Hawkes Bay Posts: 4 ![]() ![]() ![]() |
I've done this once when removing a rocker cover for replacement. Constructed a simple slide hammer out of a piece of pipe welded onto a nut with the correct thread for the injector end. They came out pretty easily - way different to those in the supercharged V8 which don't appear to have a thread you can attach with a nut. Good luck. |
Kiwi RR, no force is needed to remove the TDV8 injectors, I have not heard of anyone having to use more than a firm twist by hand to get them loose. The issue is no physical room with the back injectors to clear the engine/rocker cover
2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
They did come out easily - I think we went that way as it’s recommended in the FSM - either way it’s not too hard. Pulled the glow plugs the other day as well - was very pleased they came out without a hitch! |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 731 ![]() ![]() |
I've just done the cam cover gasket on my 3.6 (LH side of engine viewed from drivers seat)
Getting the covers off the 3.6 is easy enough but the 4.4 ones look a dog to do as you can't get to the bolts.
