Home > Technical (L322) > 4.4 TDV8 Injector Removal
dhallworth
I'm working on a friends 4.4 TDV8 and it looks like I need to remove the injectors from it.
Has anybody got any hands on experience of removing a diesel injector from a 4.4 Diesel?
Looking at the workshop manual, it looks to be a right pain in the backside to do. I'd love to hear from someone who's actually done the job though!
There's a video on YouTube of someone removing them but they've already got all the covers, etc. removed from the engine and they're straight onto the injectors.
Thanks,
Post #705752 30th Nov 2024 1:24am
dhallworth
I'm guessing nobody has had to replace an injector on the 4.4 then Sad
It doesn't look a fun job going by the manual. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #706123 5th Dec 2024 12:36am
Merchy
I could be way off target here, but is this any use? - very little info on the web is seems, the only videos I found were not helpful at all.
https://www.fullfatrr.com/forum/topic60713...tor+8+tdv8
Does not look like an easy job, hope all goes well Thumbs Up
Post #706139 5th Dec 2024 10:28am
dhallworth
Cheers Merchy,
On the 3.6 getting down to the injectors isn't difficult. On the 4.4 it's a totally different ball game unfortunately Sad
Post #706203 6th Dec 2024 12:46am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I presume you have watched this video? https://www.youtube.com/watch?v=2_A4su7rSyU
Seems the same issue on the 3.6, no 4 and 8 no room. If the 4.4 engine mounts are the same as the 3.6 I would suggest try the engine lift after loosening the bolt. If not bash out an indent in the body, it will be covered up afterward by the Battery surround. It looks like a whole lot less involved than on the 3.6.
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #706208 6th Dec 2024 1:20am
Mikeerhymes
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Re: 4.4 TDV8 Injector Removal
Thanks,
David.
Hi David, how did you get on, any tips?
Post #713073 1st Mar 2025 12:11pm
pcourtney
Wayne is bang on the money, when I had some injector woes last year, we removed all 8 and sent them off to Colchester for inspection and cleaning
https://www.colfuel.co.uk/
Only number 8 was a real pain to remove, and so we had to cut a notch / indent out of the bodywork to remove no 8 in the end, no need for engine lift or anything dramatic like that
When they came back from Colfuel we found out that number 5 had to be replaced, and now she runs perfect !
If you have a blown injector you should get the seat of the injector cut, you will need the right size injector seat cutter to do this, my mechanic used a Laser tools set to do this common job.
at 20 mins and 30 secs into the video you can see the struggle that he is having with injector 8
Post #713079 1st Mar 2025 1:22pm
dhallworth
I've not done the job yet. Removing the covers over the injectors looks to be a horrendous job. There's 7 nuts on them and they look almost invisible from the top. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #713128 1st Mar 2025 11:14pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
On the 3.6 which has issues getting 4&8 out, my indy said they use a ratchet strap and hoik the engine over to the side to give a few mm of wiggle room. Not sure what they attach it to though.
Post #713202 2nd Mar 2025 9:23pm
Kiwi RR
New Zealand 2014 Range Rover HSE SDV8 Fuji White
I've done this once when removing a rocker cover for replacement. Constructed a simple slide hammer out of a piece of pipe welded onto a nut with the correct thread for the injector end. They came out pretty easily - way different to those in the supercharged V8 which don't appear to have a thread you can attach with a nut. Good luck.
Post #713212 3rd Mar 2025 8:25am
wayneg
Kiwi RR, no force is needed to remove the TDV8 injectors, I have not heard of anyone having to use more than a firm twist by hand to get them loose. The issue is no physical room with the back injectors to clear the engine/rocker cover
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #713233 3rd Mar 2025 12:10pm
Kiwi RR
They did come out easily - I think we went that way as it’s recommended in the FSM - either way it’s not too hard. Pulled the glow plugs the other day as well - was very pleased they came out without a hitch!
Post #713253 3rd Mar 2025 7:08pm
MarianaWestminster
I've just done the cam cover gasket on my 3.6 (LH side of engine viewed from drivers seat)
To remove injector 8 I loosened the engine mount bolt (center of the mount, visible by looking down the side of the engine) I didn't remove it all the way but had about 10mm of thread showing on it.
I then positioned my jack underneath the front diff with a block of wood and a piece of high density foam as padding.
Jacked up the on the diff which canted the engine over just enough to remove injector no 8.
I imagine I'd be a very similar process on the 4.4.
Post #713271 4th Mar 2025 12:10am
dhallworth
Getting the covers off the 3.6 is easy enough but the 4.4 ones look a dog to do as you can't get to the bolts.
Will need to give it another look shortly.
Post #713272 4th Mar 2025 12:34am
