Home > Technical (L322) > FBH remote
ashtrucker
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
FBH remote
If my 2012 Westminster 4.4 is fitted with a t91r receiver can I use a r91r remote sorry if this has been asked before
Post #705069 21st Nov 2024 4:58pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
Yes you should be able to. You don't need a Landrover one, remotes from VW & Skoda will be fine and I've noticed T91 versions also work, no LR versions are readily available and a lot cheaper than LR branded version.
My own one is a Skoda version I got from over EBAY from Lithuania, works fine.
Newer remotes won't work though, hence the rarity.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #705104 21st Nov 2024 10:24pm
ashtrucker
Thanks for the info did you get t91 or t91r
Post #705112 22nd Nov 2024 3:36am
AndyRoo
Hi, the one I have now was a T91.
But make sure you get the version with "on" & "off", do not get the version with the picture of the radiator on it, those don't work.
Post #705126 22nd Nov 2024 11:39am
