Home > Technical (L322) > FBH remote
ashtrucker
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
FBH remote
If my 2012 Westminster 4.4 is fitted with a t91r receiver can I use a r91r remote sorry if this has been asked before
Post #705069 21st Nov 2024 5:58pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
Yes you should be able to. You don't need a Landrover one, remotes from VW & Skoda will be fine and I've noticed T91 versions also work, no LR versions are readily available and a lot cheaper than LR branded version.
My own one is a Skoda version I got from over EBAY from Lithuania, works fine.
Newer remotes won't work though, hence the rarity.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #705104 21st Nov 2024 11:24pm
ashtrucker
Thanks for the info did you get t91 or t91r
Post #705112 22nd Nov 2024 4:36am
AndyRoo
Hi, the one I have now was a T91.
But make sure you get the version with "on" & "off", do not get the version with the picture of the radiator on it, those don't work.
Post #705126 22nd Nov 2024 12:39pm
ashtrucker
Well got myself a remote of flea bay £110 did the programming process worked first time can’t Waite for some cold mornings to see how good it really is
 2012 Westminster 4.4 tdv8
Post #706676 12th Dec 2024 11:16am
AndyRoo
Hi, don't expect a lot, it only turns the FBH on or off on a cold day, from up to about 20 feet away, all the usual parameters still apply, also does remote fresh air on a hot day.
All the brains are in the car, make sure you have heating on auto in the centre round knob.
Good Luck.
Post #706713 12th Dec 2024 5:29pm
ashtrucker
Thanks 2012 Westminster 4.4 tdv8
Post #706715 12th Dec 2024 5:53pm
Johngrab
United Kingdom 2013 Range Rover Vogue SDV8 Fuji White
I have one for sale £50 posted
Post #706860 14th Dec 2024 2:48pm
Johngrab
Post #706861 14th Dec 2024 2:50pm
ashtrucker
Thanks but got one the other day 2012 Westminster 4.4 tdv8
Post #706862 14th Dec 2024 2:53pm
Huz
United Kingdom 2011 Range Rover Vogue TDV8 Fuji White
Hi John, is this remote still up for grabs?
Cheers
Post #708301 4th Jan 2025 9:40pm
Johngrab
Yes still for sale mate
Post #708302 4th Jan 2025 9:55pm
