Home > Technical (L322) > Ran the pre heater now loads of faults |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8334 |
Classic low voltage faults... Pete
20th Nov 2024 6:46pm |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 |
Had the car on charge all night turned ignition on still the same results and every time I try to clear the faults half way through the process of clearing I see “update failed” flash up quickly then all the codes stay the same the battery was bought in match 2023 and I got the best I could any ideas is it still pointing to battery
21st Nov 2024 7:00am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
What are the actual faults rather than the list by ecu and did you do this with the engine running as this will have maintained the voltage via the alternator to eliminate low voltage issues with the GAP tool. 2012 TDV8 Vogue (L322) |
21st Nov 2024 8:24am |
Yes tried with running showing 14.2 v I think and still no joy I’ll try to get the faults again and post up 2012 Range Rover Westminster 4.4 TDV8
21st Nov 2024 8:39am |
You can export the full detailed list of the faults vie the lower left blue icon. 2012 TDV8 Vogue (L322) |
21st Nov 2024 9:03am |
Fault codes
21st Nov 2024 9:37am |
Most of those are spurious codes thrown when the voltage drops. Replacement batteries from Tayna are not that expensive so maybe worth changing it. At least there's no alternator faults showing. 2012 TDV8 Vogue (L322) |
21st Nov 2024 10:30am |
Battery voltage on the screen shot is showing 12.2v after a charge, battery has failed.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
21st Nov 2024 12:06pm |
Not great for an 18 month old battery but it’s covered by warranty. But even when fully charged inc charger still on the codes won’t clear and you can’t engage gear 2012 Range Rover Westminster 4.4 TDV8
21st Nov 2024 12:37pm |
Local garage checked the battery and it’s ok so hard reset to do then I’m stuck for ideas almost all the faults relate to list communication with the transmission module, is there a plug that could have got damp like my old disco, need the car to take swimbo for her chemo turning up in the old works can is t going down well 2012 Range Rover Westminster 4.4 TDV8
21st Nov 2024 3:43pm |
