Home > Technical (L322) > Ran the pre heater now loads of faults
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
So as it’s cold I ran the pre heater for 15mins before leaving work, got in to a nice warm car, pressed the button to start there wash a few seconds delay which I assumed is due to the cold then she fired up and ran a treat unfortunately that’s when it all went wrong, got loads of faults, adaptive dampers, parking break, gearbox, abs, and lots more, I assumed a low battery so decided to take it for a run to get battery charged up but no I couldn’t as the gear knob was stuck down 😡.
So I plugged in my GAP tool cleared all the faults but they immediately came back up, got my charger on and even asked my local garage to take a look and even with the snap on diagnostic tool all the faults came back, battery was at 11.7 it’s only 2 years old, I’ve left it on trickle charge overnight, hoping it will sort it out but a bit concerned that even the gap tool couldn’t sort it
Apart from low voltage is there anything else I should be looking at
Thanks in advance
Craig 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #704942 20th Nov 2024 6:15pm
Classic low voltage faults... Thumbs Up Pete
Post #704946 20th Nov 2024 6:46pm
Furnitureman
Had the car on charge all night turned ignition on still the same results and every time I try to clear the faults half way through the process of clearing I see “update failed” flash up quickly then all the codes stay the same the battery was bought in match 2023 and I got the best I could any ideas is it still pointing to battery
Battery on 12.2 v doesn’t look good to
Me but it started the car no problems 2012 Range Rover Westminster 4.4 TDV8
Post #704982 21st Nov 2024 7:00am
JayGee
What are the actual faults rather than the list by ecu and did you do this with the engine running as this will have maintained the voltage via the alternator to eliminate low voltage issues with the GAP tool. 2012 TDV8 Vogue (L322)
Post #704987 21st Nov 2024 8:24am
Furnitureman
Yes tried with running showing 14.2 v I think and still no joy I’ll try to get the faults again and post up 2012 Range Rover Westminster 4.4 TDV8
Post #704989 21st Nov 2024 8:39am
JayGee
You can export the full detailed list of the faults vie the lower left blue icon. 2012 TDV8 Vogue (L322)
Post #704990 21st Nov 2024 9:03am
Furnitureman
Fault codes
Post #704993 21st Nov 2024 9:37am
JayGee
Most of those are spurious codes thrown when the voltage drops. Replacement batteries from Tayna are not that expensive so maybe worth changing it. At least there's no alternator faults showing. 2012 TDV8 Vogue (L322)
Post #705000 21st Nov 2024 10:30am
Battery voltage on the screen shot is showing 12.2v after a charge, battery has failed.... Thumbs Up Pete
Post #705030 21st Nov 2024 12:06pm
Furnitureman
Not great for an 18 month old battery but it’s covered by warranty. But even when fully charged inc charger still on the codes won’t clear and you can’t engage gear 2012 Range Rover Westminster 4.4 TDV8
Post #705038 21st Nov 2024 12:37pm
Furnitureman
Local garage checked the battery and it’s ok so hard reset to do then I’m stuck for ideas almost all the faults relate to list communication with the transmission module, is there a plug that could have got damp like my old disco, need the car to take swimbo for her chemo turning up in the old works can is t going down well 2012 Range Rover Westminster 4.4 TDV8
Post #705057 21st Nov 2024 3:43pm
