![]() | Home > Technical (L405) > Starter Clicking Problem |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1393 ![]() ![]() ![]() |
The intermittent non-starting and getting a click when the starter button is pressed is what happened to my 2012 WM. A new starter motor was fitted and the problem went away. There are several threads on the 322 section about this. So it might be the same thing on your 405. Only Range Rovers since 1988 |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1589 ![]() ![]() ![]() |
Yes, agree with CS, could be starter relay fault, starter motor fault, weak battery, or corroded earth fault. You need to check for all of these and rule out. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
The 405 also suffers with corrosion in the junction box for the main battery cable in the OSF arch |
Paulw Member Since: 29 Nov 2023 Location: Norwich Posts: 5 ![]() ![]() ![]() |
Thanks for the info guys. Good call Mikey, I hadn’t heard of this issue. How do I get to that junction box to check. |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
Don't suppose someone has a picture or schematic of this location please? Cheers James |
