Home > Technical (L405) > Starter Clicking Problem
Paulw
United Kingdom 2014 Range Rover Vogue SE SDV8 Loire Blue
I have a 2014 Vogue ( twin battery but not start/stop). It’s a 4.4 L version. I have been getting intermittent starting problems where the car will randomly not start, just gives a series of clicks with about half second intervals. When it does this the fault will remain for hours and I normally leave it overnight, then it will fire up first go next morning. The fault may then not appear again for weeks. It happened yesterday and this time I tried jump starting from the posts under the bonnet. The jump start attempt made no difference to the fault and the starter just kept clicking. I’ve today had the main battery tested and that passed as good. In the past a local garage replaced the starter relay saying it cured the fault, and on one occasion an AA patrolman got the starter to work from under the car saying he thought the starter itself was good. So I’m thinking there’s an intermittent wiring issue somewhere. I’m puzzled as to why the jump start didn’t work, so any advice would be welcome
Post #704758 18th Nov 2024 9:36pm
CS
The intermittent non-starting and getting a click when the starter button is pressed is what happened to my 2012 WM. A new starter motor was fitted and the problem went away. There are several threads on the 322 section about this. So it might be the same thing on your 405. Only Range Rovers since 1988
Post #704762 18th Nov 2024 9:54pm
Gremlin500
Yes, agree with CS, could be starter relay fault, starter motor fault, weak battery, or corroded earth fault. You need to check for all of these and rule out. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #704770 18th Nov 2024 10:55pm
Mikey
The 405 also suffers with corrosion in the junction box for the main battery cable in the OSF arch Thumbs Up
Post #704779 19th Nov 2024 7:12am
Paulw
Thanks for the info guys. Good call Mikey, I hadn’t heard of this issue. How do I get to that junction box to check.
Post #704780 19th Nov 2024 7:27am
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Don't suppose someone has a picture or schematic of this location please? Cheers
James
Post #704781 19th Nov 2024 7:30am
