Home > Technical (L322) > L322 2012 height sensors
fredd589
Morning,
Wondering if someone could help me with some height sensor trouble! Yesterday I got a c1130-66 fault and this morning on my drive to work I checked the height sensor voltages to see what is going on;
Driving:
FR 1.70v
FL 3.38v
RR 2.10v
RL 2.62
Access:
FR 1.38
FL 3.62
RR 1.55
RL 3.08
Off-road:
FR 2.23
FL 2.58
RR 2.52
RL 2.52
By the above, I would say the front right airbag needs replacing, but I want to make sure others agree, as they aren't cheap!
Thank you!
Post #703861 6th Nov 2024 8:10am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Have you tried a ride height calibration?
See: https://youtu.be/9ot3L4CHPd4?si=hAsTzMuBJoR4E9B4
About 20 mins in.
It may also be the supply pipe and/or the gland between pipe and bag. Worth checking before jumping in a buying new struts or a bag. TDV8 4.4 2012
Post #703862 6th Nov 2024 8:23am
fredd589
That's a good point - I haven't yet, and I do have my GAP tool, so I can do it - I'll try at lunch. Thank you!
The car has also had a bit of suspension work in the last few months, with two rear shocks, new control arms at the front and a 4 wheel alignment - but no height calibration.
Post #703863 6th Nov 2024 8:24am
GraemeS
The height sensor voltages are different front and rear and one side pair increase in voltage whilst the other side pair decrease in voltage as height changes.
Post #703875 6th Nov 2024 11:29am
fredd589
Thanks Graeme - that makes sense - I guess what confused me was the big difference between both the front sensors when the vehicle is moving, as I was expecting these to be the same,
Post #703876 6th Nov 2024 11:30am
GraemeS
LR has used different implementations across its vehicles, with RRs up to the L322 and L320 having 1 side increase while the other side descreases, D3 MY05/MY06 all increasing or decreasing but MY07+ and D4s having the diagonals increasing or decreasing which is what LR settled on for the L405, L494, L462 Discovery and the L663 Defender. I don't know about the Velar but suspect the same.
Post #703912 6th Nov 2024 7:48pm
