Home > Technical (L322) > Coolant Level Low (after having oil cooler changed) |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 209 |
Is it actually losing coolant? as the coolant level low message is a common fault, fixed by either changing the sensor or the coolant reservoir itself. |
2nd Nov 2024 9:03pm |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 200 |
thank you for the reply, no, not losing coolant |
2nd Nov 2024 9:06pm |
It’ll probably be the sensor, easier to change the whole coolant reservoir. |
2nd Nov 2024 9:09pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 867 |
It’s not unusual for a failing oil cooler to contaminate the coolant with oil which then shows up in the expansion tank, requiring replacement as part of the job, as well as a thorough flushing of the system.
2nd Nov 2024 9:23pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Change the tank, its £30ish and they often fail when you drain the coolant to perform a job... |
2nd Nov 2024 10:04pm |
