![]() | Home > Technical (L322) > Coolant Level Low (after having oil cooler changed) |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 221 ![]() ![]() ![]() |
Is it actually losing coolant? as the coolant level low message is a common fault, fixed by either changing the sensor or the coolant reservoir itself. |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 206 ![]() ![]() ![]() |
thank you for the reply, no, not losing coolant |
It’ll probably be the sensor, easier to change the whole coolant reservoir. |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 901 ![]() ![]() ![]() |
It’s not unusual for a failing oil cooler to contaminate the coolant with oil which then shows up in the expansion tank, requiring replacement as part of the job, as well as a thorough flushing of the system.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Change the tank, its £30ish and they often fail when you drain the coolant to perform a job... |
